Special tools_ Rear Drive Axle/Differential — Ford 10.50-Manual Transaxle/Transmission — ZF 6-Speed
This set includes:
308-375 Remover, Input Shaft Oil Seal 308-379 Installer, Input Shaft Oil Seal Manual Transaxle/Transmission — ZF 6-Speed : Excursion : 2004,F-250/350/450/550 Super Duty 04-2010 308-380 Centerplate Legs Manual Transaxle/Transmission — ZF 6-Speed : Excursion : 2004,F-250/350/450/550 Super Duty 04-2010 308-381 Fixture, Gear Pack Manual Transaxle/Transmission — ZF 6-Speed : Excursion : 2004,F-250/350/450/550 Super Duty 04-2010 308-382 Installer, Output Shaft Oil Seal (4x2) Manual Transaxle/Transmission — ZF 6-Speed : Excursion : 2004,F-250/350/450/550 Super Duty 04-2010 308-383 Installer, Output Shaft Oil Seal (4x4) Manual Transaxle/Transmission — ZF 6-Speed : Excursion : 2004,F-250/350/450/550 Super Duty 04-2010 308-384 Installer, Countershaft Rear Bearing Manual Transaxle/Transmission — ZF 6-Speed : Excursion : 2004,F-250/350/450/550 Super Duty 04-2010 308-387 Sleeve, Shifter Boot 308-388 Installer, Countershaft Bearing Cup Manual Transaxle/Transmission — ZF 6-Speed : Excursion : 2004,F-250/350/450/550 Super Duty 04-2010 308-389 Installer, Centerplate Mainshaft Bearing Cup Manual Transaxle/Transmission — ZF 6-Speed : Excursion : 2004,F-250/350/450/550 Super Duty 04-2010 308-390 Installer, Centerplate Front Bearing Cup Manual Transaxle/Transmission — ZF 6-Speed : Excursion : 2004,F-250/350/450/550 Super Duty 04-2010 308-391 Installer, Input Shaft Bearing Cup Rear Drive Axle/Differential — Ford 10.50-Manual Transaxle/Transmission — ZF 6-Speed Excursion : 2004,F-250/350/450/550 Super Duty 04-2011 308-393 Collets, Input Shaft Bearing Cup 308 - Manual Transmission / Clutch http://i1275.photobucket.com/albums/...ps5f4adf7f.jpghttp://i1275.photobucket.com/albums/...psbc497ef4.jpg $245.00 FOR ALL or best offer- "No reasonable offer will be refused!" Please Call Ray at 512-845-4844 or raybx01@gmail.com We accept Credit Cards ( Visa, Master Card, AMEX) -reference available upon request. “The tools are not showing in these picture’s, may be missing and does not come with this set” |
Still have the set?
Ray is not a member any more as far as I know. That post is pushing 4 years old.
You might try the Gmail address in his signature. Sean <BR> https://cimg0.ibsrv.net/gimg/www.for...455b8d603e.gif 6.0L Tech Folder :oval |
