transmissions for 1959 ford truck
hi guys wondering what kind of transmission would a 1959 ford truck have it has a 272 engine its a 3 speed but kinda wondering what the part number is on the side of the transmission because the guy has about 15 transmissions and i just want to spot the one i need so i need some numbers or any pictures you have of a transmission thank you very much
i will try to take a picture for you and get the number this evening when i get home from work.
Ford 3 speed transmission, non syncro 1st gear. Numbers marked on transmission parts are ONLY related to the parts they are marked on. Do not define which trans it is.
TRANS ID tag bolted to case, is probably missing by now. |
