Full Floating Axle -- Dana(50)(60)F-250/350/450/550 2004-2011
this set includes:
205-420 Remover, Wheel Hub Outer Bearing Cup (10 1/2") 205-421 Remover, Wheel Hub Inner Bearing Cup (10 1/2") 205-422 Installer, Wheel Hub Oil Seal (10 1/2") 205-423 Depth Gauge, Drive Pinion (10 1/2") 205-424 Installer, RH Differential Carrier Oil Seal (Dana 50) 205-425 Installer, LH Differential Carrier Oil Seal (Dana 50) 205-426 Installer, RH Differential Carrier Oil Seal (Dana 60) 205-427 Installer, LH Differential Carrier Oil Seal (Dana 60) 205-428 Spreader Bar, Oil Seal 205-429 Installer, Wheel Knuckle Oil Seal 205-430 Collets, Differential Carrier Bearing 205-431 Retaining Ring, Differential Carrier Bearing 205-432 Step Plate, Differential Carrier Bearing 205-433 Remover, Yoke 205-435 Installer, Differential Yoke 205-436 Installer Thread Sleeve, Yoke 205-437 Installer, Drive Nut, Yoke 205-439 Remover/Installer, Drive Pinion Oil Seal 205-440 Remover/Installer, Drive Pinion Oil Seal 205-445 Installer, Wheel Hub Inner Oil Seal These Tools was moved after Ford dealership closure. $ 299.00 or best offer- "No reasonable offer will be refused!" raybx01@gmail.com or Please Call Ray at 512-845-4844 We accept Credit Cards ( Visa, Master Card, AMEX) -reference available upon request. I can ship Overnight or two day shipping. You decide, you are in control.( I do not ship overseas) http://i1275.photobucket.com/albums/...ps04db96a3.jpg http://i1275.photobucket.com/albums/...ps3d945e0b.jpg http://i1275.photobucket.com/albums/...psf7a5a37b.jpg |
