2003 7.3 fuel level sensor (after market)
So I managed to destroy my fuel level sensor located in the tank of my 2003 7.3 long bed dually.
I called Ford to identify and price another sensor and to my surprise the cost of the sensor that appears to have the float w/rod attached is worth more than the weight of gold when weighed ounce for ounce! My only thought for the cost of this device is that maybe they used actual silver for the sensor parts! Nearly 500 bux! Just wondering if anybody else has a source for an after market in-tank fuel level sensor that works with the in-dash controls that is a little more durable than the OEM sensor..... Thanks, Kevin |
I have not personally done it, but try pricing the cost of the same tank size(38 gallon on a long bed) but with a gas motor(You can purchase just the sender rather than the entire pickup), should be cheaper and will only require slight changes such as bolting(screwing) instead of rivoting.
Ditto what Al said. :-X22
Originally Posted by BigAlsPSD
(Post 12588785)
The cost I have is just for the sender that has the float attached. It then snaps to the mixing chamber. The sender and rod with a float is all you get for 425 bux before tax..... |
Did you try www.tousleyford.com there a sponsor on here.
Originally Posted by kweiss
(Post 12589069)
The sender and rod with a float is all you get for 425 bux before taxfuel..... Also ask them for the part number for a gasser with the same size tank. |
After pulling it up on the computer it appears the sensor comes with the mixing chamber but really all I need is the sensor but I guess you get a few other items that is not needed.. the number for the part can be found in the attachment as 9275....
2003 Ford F-350 Fuel Pump and Sender Assembly | FordParts.com Super Duty |
(Post 12591244)
2003 Ford F-350 Fuel Pump and Sender Assembly | FordParts.com Super Duty This is the best pick I have. It shows the back of the bracket that the fuel level sender mounts to. This is for a diesel and the fuel level sender is riveted to the bracket. A gasser fuel level sender can be mounted here by drilling out the rivets and using screws or nuts and bolts. https://www.ford-trucks.com/forums/a...4&d=1343086536 |
Originally Posted by PaysonPSD
(Post 12592186)
The part in the link is the whole assembly (Fuel Sender) including a FUEL PUMP, which means it is for a gasser. The diesels do not have a fuel pump in the tank. What you need is the Fuel Level Sender.
This is the best pick I have. It shows the back of the bracket that the fuel level sender mounts to. This is for a diesel and the fuel level sender is riveted to the bracket. A gasser fuel level sender can be mounted here by drilling out the rivets and using screws or nuts and bolts. https://www.ford-trucks.com/forums/a...4&d=1343086536 Guess I need to check the price on the gas guy and see if its any cheaper like you guys mentioned....it must be sold with out the mix chamber possibly. |
(Post 12592199)
Yup...that is exactly what I took in to the dealer and showed what I needed and he quoted that much for the sending unit. The attachment link I sent looks as though its sold with the mixing chamber attached. SO maybe the fella I spoke to was loooking at the wrong thing.
Guess I need to check the price on the gas guy and see if its any cheaper like you guys mentioned....it must be sold with out the mix chamber possibly. Check this LINK. It shows separate fuel LEVEL senders for gassers and the whole fuel sending units for the diesel. Noter: there are both midship and after axle tank fuel level senders or whole fuel sending units (diesel). You can use the info and/or the enlarged pics to show a Ford parts guy. |
