Update; Radiator spewing and limp mode fixed, with pictures.
The new OEM arrived and it is not the same as the aftermarket one. The bypass valve is only open 1/8" when cold and the main valve opens after boiling. See pics;
http://i661.photobucket.com/albums/u...%20pics/t1.jpg This picture shows how long the bypass valve is and it restricted the block circulation flow. New OEM on left http://i661.photobucket.com/albums/u...%20pics/t2.jpg This shows the Motorcraft one on the left fully open and the bypass valve is now extended more than the other which directs all the water through the radiator. http://i661.photobucket.com/albums/u...%20pics/t3.jpg This shows the old one (actually new) finally opening after 5 minutes of boiling. http://i661.photobucket.com/albums/u...%20pics/t4.jpg This is what the bypass system looks like that warms the water faster in the engine before it is all directed to the radiator. Here is some reading on it; http://www.are.com.au/feat/techt/thermostat.htm <cite>You will have to copy and paste above into Google etc to see how the bypass works (A R E Cooling)</cite> <cite></cite> |
Dang. LOL.
I guess the thermostats are generally so much better now that we tend to forget about them. Good Job finding it! Remember how thermostats used to go on vehicles 30+ years ago all the time? I can't think of more than one in the last 15 years that I've replaced! REP TIME!! Edit: crud. I'm in replock on ya. |
Originally Posted by housedad
(Post 12562643)
Dang. LOL.
Great info.
glad i usually buy oem for the less expensive parts. just not worth saving $10 sometimes.. |
Hopefully that fixes the problem. It's amazing how the little details can make such a drastic difference in performance. I got him for you Bion. :-X22
So the moral of the story is when you need a new thermostat buy the Motorcraft one? Glad you got it fixed.
Originally Posted by sammie0126
(Post 12562875)
So no more limp mode?
Stewart |
Originally Posted by Stewart_H
(Post 12563207)
Stewart |
