need a good garage in Norfolk or VA Beach area
how do everyone? I am in desperate need of a good quote for some work on my 6.0. I have the parts, I just need labor. I am doing an EGR delete, oil cooler replacement, ARP studs with Black Onyx gaskets. Any help would be great. Thanks.
I would recommend Twisted Diesel. They are in Chesapeake so not to far from where you are looking. Ask for Buddy.
They did my 6.0 Excursion. They are a great shop and work fast. I would recommend against doing the Black Onyx gaskets though and return them if you can, stick with OEM gaskets which are far superior to the BOX's which have a pretty high failure rate on this board. |
Thanks, I will definitely check them out. How much was it if you dont mind me asking?
It was several thousand but I dont remember the breakdown since I bought parts from them as well. They did my exhaust and tune at the same time.
What tuner are you going to use? |
I currently have a BANKS power PDA, 4 inch turbo back exhaust, AER intake.
So it should just be labor and fluids. Are you going to rebuild the oil cooler while they are in there?
Oil cooler replacement and EGR cooler delete
