Will a HD grill fit in a 03 f150
I was wondering if a Hd grill or Lighting would fit in a 03 f150
Thanks Jason |
A Lightning should fit. The SD has a totally different doghouse.
yeah a harly grill will fit it's exactly the same
mine has the HD grille they all interchange with no problems.same with the headlamps parklamps and so forth.
what year was the grill that is off your truck? How much was the grill?
Thanks Jason |
i messed up and put the 2000 grille in mine before i seen the 03 grille the new one is MUCH NICER. it cost over 300 and you have to paint it to match. unless your truck is black. every part of my truck except the roll pan and tail lamps are ford either harley lightning or reg f-150.
