94 lightning computer
does anyone know where the computers code is at....and hows the easest way to get the computer out of the truck it appears to be alittle hard to get to form inside.
look under your master cylinder and you will see a long grey plug...on the other side of your firewall is your computer...if it doesnt have a chip in it you can pull it out after you unbolt the rubber shroud from it...i just changed mine today...was a pain unti i figured this stuff out
There should be a sticker on the front driver side door jamb at the top of fender. There are a couple of ways to remove the computer. I don't know which is easier.
1 - Remove emergency brake assembly/ kick panel. 2 - Loosen bottom of driverside fender/inner fender. |
