which axle is this?
1 Attachment(s)
I beleive this is the 44 LP correct? If so are they as good as the HP or should I keep looking for the HP?
Thanks Tim |
The HP is a lot more desirable and I think stronger as well.
thats what i have been looking for but can't find one. This is the LP right? just wanted to make sure this is no the HP and I didn't think it was.
hp puts the pinion above axle centerline and lp puts it below centerline. thats clearly lp.
definitely low pinion. Low pinion is supposedly weaker on a front axle, and stronger on a rear axle, because of the way they turn. But the main reason people like the high pinion front axles are because first off, it gives you way better angles on the short front shaft, and second, it gets the pinion up off the ground. On a low pinion front axle the pinion is one of the lowest spots on the truck so its common to damage the pinion/ujoint/shaft area on rocks and stumps.
It depends on what you are doing, but the high pinion 44's aren't that hard to find, are relatively inexpensive, and are probably worth holding out for. But if the LP is free and meets yours needs then by all means go for it. |
It's a LP..... 44HD (sent you a PM).
Originally Posted by hasteranger
(Post 12465099)
It depends on what you are doing, but the high pinion 44's aren't that hard to find, are relatively inexpensive, and are probably worth holding out for. But if the LP is free and meets yours needs then by all means go for it. I am unable to find a HP here in Vegas for less than $8-900. I wont pay that much. This LP is up in Utah and not to far away but its not what i want. I will wait for the HP. Thanks for the Info |
Originally Posted by elkarcher1716
(Post 12466965)
Originally Posted by montana_highboy
(Post 12467017)
Those are HP60 prices! i'm not familiar with the Vegas market but a HP44 shouldn't be anymore than $200
Nope thats what they are asking for around here, atleast what i am finding.
keep looking for just buy one off ebay and ship it. **** if they are actually selling for that you could buy all of em off ebay, ship them, and make money! lol
That's foolish, I paid $40 for a HP44 that has the welded on wedges with everything right out to the tires and a few weeks later was given another fully complete HP44 with cast wedges for free.
I have a HP dana 44, everything works great, needs ball joints. I'd sell it for $250. but I'm not sure what shipping would be.
Edit. Its leaf sprung too |
I guess it would depend on shipping. I keep looking around here also. If you feel up to is see what it would cost to ship to 89032. I might be able to get a loading dock also.
(Post 12485024)
if you needed a coil one, I could do it cheaper. |
