1995 F-350 Lifted 460. Single Cab Long Bed
Located in Mansfield, TX
Have a baby on the way, but im in no hurry to sell. I absolutely love this beast and hate to part with it I just have too many vehicles. I put a lot of work in this truck and its ready to take a beating, pull anything, go muding, or travel anywhere. This truck is an 1995 F350, 460ci 7.5L, E4OD auto with manual borg warner transfer case with PTO available. Truck is an XLT, 60/40/60 buckets, AC cold, electric windows, cruise control (works!), Truck has a 10.25 Sterling rear axle, full floating, and big dana 60 front axle. Truck has 240,000 someting miles! But just about everything has been touched or rebuilt...Was told engine was rebuilt when I bought it, cant verify. Engine runs strong as hell, does not smoke, or burn oil, no check engine light. Engine runs cool, even in summer traffic towing it will NEVER over heat. I bought this truck about three years ago and fixed all the issues with it, made it reliable, then lifted it with a SKY 3" Front reverse shackle kit, rear SKY flip kit. and add-a-leaf front springs. Added military 37" OZ tires on from a Hummer, pitman arm drop. Truck is lifted about 6 inches over stock. Hummer tires are hard, so they last on the street, they are 8 ply so ride like a rock and can tow :) I then put on a custom roll pan and tailgate. Removed the fuel filler doors and made custom fuel filler shroud with locking caps. Put in a sony stereo with sub woofer, installed a overhead console from an explorer. Engine has new radiator, new Motorcraft waterpump, new wires, plugs, MSD cap, K&N filter with modded intake. Truck has a ton of torque, enough to spin the 37s, no problem. 4x4 works, has new cardian joint and new hubs. Engine code is clean, no coded. Exhaust is 3" Flowmaster 40, cats have been deleted, to side exhaust. Truck has tow hitch, drop hitch, and has trailer brake controller in cab. E4OD shift good, has lockup torque converter, recently serviced transmission with new filter fluid. Reverse struggles sometimes, was told it could be ground or solenoid, fluid flushed to help the issue, hasn't happened in some time. I towed a trailer to austin and back with OD off and actually got 11.5 mpg. I have the fender flares off, but are in the garage. Truck has zero rust. Have clear title...Call Mike 817-657-0554 New / Replaced: Ford Distributor MSD Cap Motorcraft Water pump Timing Chain Radiator AC serviced New steering rods (pitman arm, centerlink, tie rod ends, drag links) skyjacker pitman arm drop Clear headlights SKY front 3" kit SKY rear kit Pro comp shocks Rear drums recently rebuilt New sony explode stereo Plus much more, sure im missing The bad: Needs paint, but who really cares in a truck this cool :) Color is light grey smoke. Needs inspected. I never had an issue with it, but needs a cat to get inspected. Front tank fuel pump is dead. Running on rear. Cracked windshield http://i632.photobucket.com/albums/u...a/IMG_1484.jpg http://i632.photobucket.com/albums/u...a/IMG_1482.jpg |
nice clean looking truck, i followed the build as it went and i really enjoyed it, goodluck with the sale bud
Thanks. I I don't get any bites I'll just keep it, rather than take a huge hit. I like it too much :)
Originally Posted by mdula
(Post 12454191)
Mean looking
