Wheels spacers
Going to need to add some spacers on the rear to get tires to clear box sides.Any brands I should stay away from?
Reg1952
What rearend are you using? |
Go to Summit Racing.
I am using a diff out of an Explorer.
IMHO, spacers are spacers. Avoid using them if you can but if you have to use them I think they're all about the same. I'd go to a reputable dealer like Summit or Jegs...:)
Igot mine from wheelspacers.ca billet machined aluminum .Very good quality . You will have to call them to place an order . Mine were about $125.00 ea.
Here is another source. Custom made to fit my Mark VIII IRS from 5 on 4.25" to 5 on 4.5". Price: $90.00 + $11.50 shipping for the pair.
https://uswheeladapters.com/ ___________________________________ 48 Ford F1 - Darkside 46 Ford Tudor - Street Rod "Happiness - 3 pedals and a 5 speed" :-jammin |
I am also using an explorer 8.8 rear and needed to get 1.25" spacers. I got them through Amazon. I believe they were 110 for both and they are machined aluminum. No problems with them and they make the width perfect.
Thanks everyone for the advice.
Originally Posted by topmoo
(Post 12451591)
Amazon.com: Rugged Ridge 15201.08 Black 1.50" Thick 5-on-4.5 Bolt Pattern Wheel Spacer Pair: Automotive |
Hey Vern,
Like Topper we also had to go with spacers with our Explorer 8.8 in. rear end - it's just a little too narrow & the wheels didn't look right in the opening. I think our's are two inch. There are a ton of decisions - If I had known going in... That said it drives fine with the spacers. Ben in Austin 1950 F1 351W/AOD |
Originally Posted by ben73058
(Post 12455267)
Hey Vern,
Hey Vern,
I used the "Tips & Tricks" article up at the top of the Forum to help in choosing a rear end. My overriding issue was to match the same lug arrangement as the Mustang II front end we put in & I liked having 4 wheel disc brakes as my son would be driving it a lot. I'm happy with how it drives but if I had it to do over I might go with a '57-'72 F100 9 inch rear end that matches the width better. The 8.8 inch we used was from an '89-'01 Explorer which has a 59 inch width according to the "Tips & Tricks". Ben in Austin 1950 F1 351W/AOD |
(Post 12455416)
Hey Vern,
Hey Vern,
No expert but what I've read: '90-'92 Rangers 8.8 axles are 56.5 inches wide '93 - 2009 Rangers 8.8 axles are 58.5 inches wide Ford Explorers have 8.8 inch axles that are 59.5 inches wide. This link is pretty informative about Ranger & Explorer 8.8 inch axles. The Ford Explorer 8.8-Inch Rear Axles "The 8.8-Inch axle used in the Explorer is highly desirable because it came with 31-spline axles over the typical 28-spline found in the Ranger version. There’s a 20-25 percent difference in strength between this Explorer 8.8 and the Ranger 8.8. The bigger 31-spline axle accounts for most of that, but the 3.25-inch tubes also help. The 1991-1994 versions had 10-Inch drum brakes and the 1995 and newer models come with disc brakes. Not all Ford Rangers came with 8.8-Inch rears. The base rear end in the Ranger has been the Ford 7.5-Inch. When Ford introduced the 4.0 V-6 into the Ranger in 1990, it came with a 8.8-Inch, 28-spline rear axle. The Ford 7.5-Inch axle was standard on the non 4.0 V-6 models. To this day, the Ranger can still be found with either the Ford 7.5 or 8.8 inch axles. The base model 8.8-inch axle is still a 28-spline, but the FX4's come with a 31-spline 8.8-Inch rear axle. The majority of these axles came with 3.73 gears and a Traction-Lok differential. The Traction-Lok can work very well and almost like a full locker if you apply a little brake pressure with your left foot while accelerating with the right." Good luck over there - Sorry about the highjack - now back to your original topic on wheel spacers. Ben in Austin 1950 F1 |
