Alternator conversion supplier
Hi guys, anyone got any leads as to where I can get and alernator conversion kit for my ' 37 21 stud, the pulley, bracket and alternator altogether at a reasonable price. Need it sent to Australia though.. Is it cheaper to buy the parts seperate?
I bought my 6v alternator kit here. A very knowledgeable guy. I had pulley alignment problems with adapting the kit to a flathead 6, so I called him and he exchanged the pulley at no charge.
Thanks. Geez his alternator price is up there !
True but not as bad as some that I've seen.
Alternator
Try these guys.
Quality Power <CITE>www.qualitypowerauto.com/</CITE> <CITE></CITE> <CITE>909-794-1600</CITE> <CITE></CITE> <CITE>Tim</CITE> |
Did Chris convert the truck to 12 volt, or leave it 6 volt?
12 volt gen but looks like its on its way out I couldnt get it charging. Think I would prefer an alternator.
Did you try to "flash the field"? Assuming that you have a generator/regulator setup:
From the NAPA/Echlin "Manual for the Automotive Electrician", edition circa 1955: Ford-Merc-Lincoln remove Field wire and touch to Batt wire momentarily; most other cars, touch jumper from Arm to Batt at regulator. For cutout 3-brush Fords, jumper between two terminals on cutout. Just a thought. This is why I went to an alternator also. |
I'll look into it... Also I see that you can oil the generator, any parcitular oil ..amount?
Quality power auto got back to me with a reasonable price for the Alt setup. |
Ive gone with quailty power auto. Answered all my emails and the price was ok to get it to Australia. All up was about $305 AUD for the whole kit bracket and fan pulley too delivered . Just to by that alternator here [a chrome one pfft who wants that] is $299!. And I have to drive 3/4 hour there and 3/4 hour back just to get it.
I'll let you know how easy it is to fit etc. |
You shouldn't have any issues with Quality Power but the are just up the freeway from me if you have any issues.
Tim |
New Alt
All has arrived , fitted no probs, must say they were a little rough when they fitted the pulley it was scratched on the inside I had to gently file it. Also quiet noisy.. Does the job.. ;)
