96 F-250 OBD-II?
Am I correct that my 96 F-250 should have OBD-II? I looked for the port, but didn't see it. Where would it be on that truck?
Also, has anyone been able to use the Bluetooth dongle and TorquePro on an Andriod for a truck this old? |
OBD 1 even my 97 is a one. the 150's changed but the HD's never did.
(unless someone has done some serious work to your truck) |
250/350 OBS trucks were exempt from OBD-II standards, unless it was a California or Massachusetts truck.
No wonder why my 96 is so reliable!
:-drink |
Your 96 F-250 will be OBDI, the connector for checking the codes is by the drivers side (left) hood hinge.. Go here to find out how to check for DTC codes without a code reader.. Fuel Injection Technical Library » How To Run a Self-Test , if you want to get a code reader the Equus 3145 is a very good one and it only runs about $25 - $30..Equus 3145 Ford Digital Code Reader : Amazon.com : Automotive
Originally Posted by White 97 xlt
(Post 12404171)
http://i357.photobucket.com/albums/o...er14000GVW.jpg |
Originally Posted by Lead Head
(Post 12403518)
Originally Posted by RIKIL
(Post 12404292)
Didn't we just do this?
Should there be several stickers on the truck that states which system
Each truck has? |
Originally Posted by khadma
(Post 12404321)
Each truck has? http://www.motorcraftservice.com/pub...38/F6AEPYA.gif |
I guess I was getting ahead of myself, since he said he didn't find an OBDII connector then there WAS a very good chance it was OBDI....
I'll just shut the hell up and leave it to the pros!!!! |
(Post 12404375)
I'll just shut the hell up and leave it to the pros!!!! I'd rather have these lumps than be wrong the rest of my life |
(Post 12404375)
I'll just shut the hell up and leave it to the pros!!!! No reason to sit in the corner, keep doing what you are doing! |
Originally Posted by rla2005
(Post 12404290)
Be very careful with that statement above. Lead Head is correct, the California emission trucks with 7.5L engines (<15,000 lb. GVW) were OBD-II starting in 1996. I know Massachusetts is pretty stringent on their emission requirements as well, but I have no documentation they were OBD-II as well.
There are also some other exceptions/oddities. For example, the 1994.5-1995 7.3 PSD trucks have both the EEC-IV test port under the hood, and an OBD-II port inside - but it doesn't work from the factory. You need to have it flashed to enable OBD-II functionality. |
(Post 12404425)
Massachusetts adopted California emissions in around '94 I believe.
Good info to know! Thanks |
