Exploded Another Muffler
Second time in the last year I lost ignition in my 360, backfired and exploded a muffler. I put an Ignitor in the distributor and a new coil 2 years ago.
Very sporadic. It has skipped maybe 5 or 6 times, and backfired the 2. Any ideas? How do I troubleshoot? |
Takes 2 things to make the bomb, fuel & spark. If you are getting fuel (gas) into the muffler (enough for an explosion) the carb needs work.
There are others here that can better prescribe a course of action. Which carb (brand & model) is currently on the truck? John :-X06 |
Originally Posted by jowilker
(Post 12388672)
There are others here that can better prescribe a course of action. Which carb (brand & model) is currently on the truck? John :-X06 There are no obvious shorts, etc. Are the Petronix Ignitors pretty dependable? Is there a way to test them? Going to do the cap and rotor thing today. |
When installed correctly, the Petronix is a very reliable solid ign. system.
John :-X06 |
Make sure the distributor is grounding properly. I had a truck once that lost spark, a friend tried getting it running again. He turned the distributor while cranking, it made the connection and blew one of the mufflers wide open.
thanks John and Jared.
I put new wires, cap and rotor on. purrs like a wildcat. the ground looked good. i think the problem was the coil wire. It looked ragged. thanks again fellers. btw, i love both your signatures |
Hey, You will have to come up with and have one of your own.
John :-X06 |
Oops, spoke too soon
Did it again this evening. There is no pattern. Was running like new, then loss of power, boom and back to full power in about 2 seconds. Strange :-arrgh
on the lighter side...
Driving this thing with no muffler raises the testosterone level about 50 points
:-X04 |
Originally Posted by elbob
(Post 12401531)
:-X04 |
(Post 12401488)
Originally Posted by rustywheel68
(Post 12403536)
is it possible that you are losing power to the coil? maybe a flaky ignition switch?
Is there a way to test or better to just replace? |
(Post 12404970)
Hey that's a possibility I didn't consider. There have been half dozen times it failed to do anything when turning the key. I assumed it was the goofy gear shift not in position.
Is there a way to test or better to just replace? but if you want to try it, here's what i'd do: disconnect the wire from the starter relay "S" terminal (so the truck won't try to start) disconnect the wire from coil +. voltmeter black lead to ground voltmeter red lead to the wire you just took off the coil + if you have a 'continuity' setting on the meter, use it. if you don't, you should be able to read ~9v at the wire with the key in start or run. (you could also do this with a test light) turn the key on/off/on/off...see if you can get it to misbehave. |
