What gear or axle ratio do I have?
The code on my VIN sticker is 15.
The tag on the differential says S V 5320 31 975 6K23 0 I took a pic of it, but not sure how to attach it to the thread. I have a 2007 Limited 2wd with the HD towing package and can't seem to find code 15 in the net. TIA! **EDIT** The 31 shows 3.73 open differential, according to this: What rear end ratio is in my Ford , do I have positraction? - Drivetrain.com But there's no 15 on that page, that's why I'm curious. |
Did you try punching your VIN into this site? It will give you the window sticker and all options.
Use your VIN number to get Ford Window Sticker |
What does your diff tag say?
Code 15 on 2007 and up Expeditions is 3:31 gears.
All non-EL's came stock with 3:31's ( 3:73's were an option ) All EL Expys come stock with 3:73 ( no options available ) *** This does not include SSV Expys ( Police Pkg ) as they had different options*** Matt |
Originally Posted by critterf1
(Post 12369698)
Originally Posted by RI-Matt
(Post 12370630)
Originally Posted by Expypate
(Post 12369505)
Originally Posted by cougar694u
(Post 12370941)
Thx! It is non-EL, so I'll assume it's the 3.31 rear end. How can you decipher the differential tag?
As for deciphering the tag ??? Don't know ??? Sorry. Matt |
I wonder if the 31 is the .31 of 3.31, but merely a guess.
Thx again! |
Cougar, copy and paste this link to see if your window sticker comes up.
After the " = " add your VIN. Note this may not work for 2007 and older as I think it only goes back 5 years and we are on MY 2013 vehicles but worth a shot. http://services.forddirect.fordvehic...icker.pdf?vin= Matt |
You're probably right, I get an XML error for invalid VIN.
