2003 Explorer P0171, P0174 codes
Hello,
2003 Ford Explorer, with P0171 and P0174 codes, common problem, as I have read. I pulled the cover over the engine off, and I immediately found the likely problem. There is a hose/connection that runs from the valve cover on the right side, about 6 inches behind the oil fill tube across and looks like it comes into the Carb. Where it turns to come into the carb is a rubber elbow. This elbow has a hole in it. Temporarily I have used electrical tape, but when I run the vehicle, I see the elbow begin to collapse. I believe the elbow is getting weak with age, plus the hole/tear doesn't help. Anyway, does anyone know of the part number, or what this is called. Hoping Advance Auto, or Napa will have it, just don't know what it is called, and can't figure out the part number. Any assistance is appreciated. Otherwise I will pull it off tomorrow and take to advance and see if they can match it. Thank you Andrew |
xxxxxxxxxx
Originally Posted by avking2508
(Post 12363862)
Thank you Andrew That's what I would do! You can check out this thread over at explorerforum to see what others have come up with: Rough idle and "Check Engine Soon" light - FIXED - Ford Explorer Ranger Enthusiasts "Serious Explorations"® Good luck. edit: caseys is right - what engine and what carb? :-) |
Sorry, of course, valid supporting information would help
4.6 engine. I am not certain on the carb. Andrew |
(Post 12364900)
4.6 engine. I am not certain on the carb. Andrew -Rod |
Problem found
Thank you rrgone
Rough idle and "Check Engine Soon" light - FIXED - Ford Explorer Ranger Enthusiasts "Serious Explorations"® Has the exact problem, with part numbers. Thank you Andrew |
