Can a heater core be repaired instead of replaced?
Hello all. I have a leak. I'm leaking coolant from what looks like the heater core, because it's actually dripping down a considerable amount of coolant right onto the floor, and it's dripping right where the heater core is located. I'm in the process of removing the heater core right now. What I'm wondering is: Once I pull out the core, what options do I have of repairing it, instead of replacing it? I've heard the replacement Chinese heater cores may not fit very well. Plus it may be less expensive to just patch a hole in my existing one. But who would I take it to to do a repair like that?
I guess a rad shop, but I usually take my chances at the repo ones. Mines still holding strong.
I got mine at napa fit fine, for under 30 bucks for a new one it really not worth attempting to repair an old one that leaks.
Any shop with enough knowledge to be able to repair a heater core will most likely charge almost as much as a replacement core. The cost difference won't be enough to buy a good burger and fries with a drink on the side.
And if they are like most, they won't touch it anyway, because the metal has work hardened and eroded inside to the point of being weak in spots, so they can't guarantee it will hold... Do your self a favor and get a new core and just do the job once and be done with it!!!!! |
I would just purchase a new core, especially with how cheap they are.
Originally Posted by garthneddy
(Post 12339686)
***Oh also: my heater core that's leaking seems to have some kind of wax in a couple of different spots. Like yellow, thick goopy blobs of wax. Do you guys think this was from a previous owner trying to repair the heater core? |
Just got done installing the $23 heater core from Napa. It fit really well actually, and no leaks now! Everything's working as it should. Thanks for the help everyone.
Originally Posted by Rockworthy
(Post 12340800)
***Oh also: my heater core that's leaking seems to have some kind of wax in a couple of different spots. Like yellow, thick goopy blobs of wax. Do you guys think this was from a previous owner trying to repair the heater core? Glad to hear you got her fixed up.... Enjoy!!!! |
