1948 F-1 Warner 4 speed pops out of 4th gear
I just rebuilt my 4 speed crash box with new bearings, shafts and thrust washers. the gears all had minimal wear so none were replaced. it is tight and smooth but pops out of fourth gear on long downhills-at slower speeds it eases itself out. at a higher speed [50-55] it poped out more violently- any advise on what to look for?:-huh
Check the detent springs in the cover, and the cluster gear end play.
Chuck |
Thanks Chuck- I will check the detent springs-I have the bullet shaped detent pins-do you know where I can locate the springs? Frank S.
Popping out of gear can be a sign of a worn synchro gear. The gear teeth may look fine, but the synchro rings are what hold it in gear.
It could also be those detent ball/springs in the housing, but usually those aren't the culprit. Dan |
Look on the bench where you did the rebuild.
That didn't actually help at all, did it? One in every crowd.. Sorry. It's a ball/spring assembly, no? The spring would be behind the ball. It's been a while since I've been inside one. I had one with a cracked synchro that was hard to get out of that gear. |
1948 F-1 warner 4 speed pops out of fourth gear
thanks to the next 2 guys but this is a SPUR GEAR 4 speed-no syncronizers.where do I find the detent springs for sale???
Originally Posted by f1ford48
(Post 12327386)
Ford used that transmission starting in the Model A years. You can get every part for the transmission you need. Often it is easier to find four speed spur gear parts in the Model A parts supplier websites. I spent a couple minutes and found this: Sacramento Vintage Ford
An even better source is: http://www.vanpeltsales.com/FH_web/t...ruck4speed.htm |
thanks-- I will check out vanpelt
