rear dana 60 brake line
hi all,I have a f250 1975 HB ,I am replacing brake lines.My question is dealing with the three way brake line connection,and breather ,how are others replaceing the flexible brake hose .I have seen pics of hard line going verticle,not sure how to approach this,or can you purchase? thanks all
Do you mean replacing the flexible hose with a hard line?? If that's the case DON'T DO IT!! You have to have a flexible line between the rear and the frame mounted hard line.
Line, axle tube to frame '75 F250 4WD D5TZ-2282-A Green Sales, Cincinnati, OH has 2 (800) 543-4959 JST Automotive, Lebanon, TN has 2 (615) 443-3086 Plus these should still be available at NAPA, Autozone etc. |
This is a bad pick of the flex line from Inline Tube. I'm sure you can get them other places as well. Once all the weight was back on the rear end I have plenty of slack.
http://i780.photobucket.com/albums/y...905_172506.jpg |
flex line rear dana 60/breather
Thanks mike Thanks grinner.Inline will set you up with all that,i didnot know that.Thanks mike for the references.
