A resistor on the IAT sensor?
I have noticed a lot of things on the web on modules that promise increased MPG and power by adding a resistor on the IAT sensor. As much as I like the idea of increased MPG and power for cheap, if it doesn't work, I don't want to waste my time.
So, what is the consensus on this type of modification? Will this mod be effective or only be a wase of time? Thanks for your thoughts! |
What not to use:
https://www.ford-trucks.com/forums/1...vp12-chip.html A great alternative: https://www.ford-trucks.com/forums/1...ed-4-14-a.html |
Waste of time.
The resistor gimmick has been around for years. It just fools the PCM into thinking the air is a different temperature so it operates the fueling system richer or leaner. It cannot both increase power (which takes more fuel) and save fuel (which reduces power). A customized tuner package can allow you to select which attribute you want. |
If you have an older vehicle which won't accept a tuner adding a resistor may throw the cel light. You will get better mileage by inflating your tires to max inflation for load on your tire ratings.
