1995 ford f150 4x4. 5 speed
hi need help,my truck is running rough and it stalls when i come to a stop,when it cold on high idle it perfect but soon as it goes of high idle it runs rough,i put new plugs and wires and rotor and cap on it but nothing changed.anyone got any ideas
Start by running the self test,
Fuel Injection Technical Library » How To Run a Self-Test Try best you can explain, explian what you mean when say "runs rough". Sounds like it has proper control of its idle at this point. You did a tune up that's a good start, usually need one anyway. Did you happen to check its fuel pressure? And the base timing, did you check the timing, determine amount of slack in the chain? Would you say it runs rich? too much fuel or starving for air, see black smoke out tail pipe? Or perhaps feel its starving for fuel? gets enough cold open loop but then too lean closed loop? |
Deleted, gotta double post.
If mod happens in, please to remove it? thanks! |
