Crossmember Needed
I’m new to the forum, I recently bought a 57 F100 Styleside (short bed), 272 with a 3 speed and I need the rear engine/transmission cross member. The PO had planned to put in a 351 with a C6 and hacked off the rear engine/transmission cross member. This conversion seems pretty common so I’m hoping that somebody has this is sitting in their garage. Also, is this the same crossmember used in the 55-56 F100’s ?
Sorry, I hacked mine out too for my diesel and ch*** transmission :-X04 gasp.. Welcome to the fridge club, where all the orphans hang out. Good to see a Seattle member. What area? See if you can get some photos up. Also we always need as much info as possible about your truck. We're not sure why, we just like these trucks and need the info. Thanks and good luck.
I can't remember if I removed mine yet or not but what pieces I did remove I drilled out the rivets, it is a 4 speed, not sure if 4 and 3 speed is the same. I'll take a look next time I get over there, not sure exactly where it might be.
I have one here that I used a saws-all to cut out right at the frame rails. I tried to remove it by the rivets but no way was I getting it out. If your interested PM me your email I'll send pics so you can determine if will work for you. That's if hotfalcoon does not come though, I do not want to cut the line. Make me an offer, it's heavy.. The truck had a 3 speed Overdrive originally.
bob |
deleted.....
Nick; I'm not sure if its the one you need, but I just seen it 1958 59 FORD TRUCK ENGINE/TRANNY MOUNT B8TZ 6038-A | eBay been on there a while now!
Good luck in your quest! Disregard its the isolator not the cross member. Sorry its late and i'm tired. |
Originally Posted by theodore/teddy
(Post 12240844)
B8TZ-6038-A = .. Upper Front Insulator = 1958/60 F500/950 & 1961/72 C500/1000 401/477/534 V8's. -------------------------------------------------------------------------------------------------- B7C-5026-A .. Rear Engine/Transmission Crossmember / Obsolete / ONE available NOS Applications: 1957/60 F100/250 / 1959/60 F100/250 4WD. OP: If you want this puppy, post your email address so I can give you the source. If I post it here, someone will snag it. |
thanks NumberDummy, it should be on the way tomorrow
member needing crossmember for 57 f100 with 272 engine
i might have what you need. i have a 60 f100 with y block engine( i dont know what size) with 3 speed trans. what mine has is a big cast iron bell housing that bolts to the frame. get in touch.
Thank, I just got a crossmember last Friday and now the fun part of getting out the old rivets. Any easy suggestions?
Nothing easy about removing Ford rivets. Get the rivet head off one side, torch or grind, then heat the rivet red hot and drive it out with a punch
Thanks, I did grind off the heads and then tried to drive them out with a punch and big hammer but no luck. I ended up drilling 2 of the rivets out but 6 more to go. If heating the rivet is easier, I'll try that.
Originally Posted by nicks_57
(Post 12283784)
Ok Bringing this back from the dead now I need one... HELP Let me know if you have one Thanks
to a4t1rat from willdavis1804@yahoo.com. I still have the truck and its all original so I should have what you need. I'm not good with emails and stuff so just give me a call at (205)915-4612. thanks, will
