Battery light after alternator change?
So heres the deal.Attempted to change the alternator on my 6.0 for failing an idle test.Batteries are new and would charge fine driving around town.Just not at idle.If i rev up to 2k they charge fine. Changed out the alt. and now have a battery light.Never had it before.Drove around town for a while and never went out.Was gonna try another alt. but they didnt have anymore.So i put the old one back on and the battery light is gone. Why would thhe battery light come on with a new alt? Oh and the new alt was a remanufactured.Gonna try a brand new one tomorrow.Hope this all makes some kind of sense
shure does make sense
I take it its an alt from a Chain store???? The Neww alternator is Bad seen this Many Many times before with chain store alternators DC Power is Hands Down the Best if you can afford it DC Powers alts have a smaller pulley so it can put out more power at Idel when you really need it most especialy when Cold out Have you cleaned all connections even the grounds where they mount tot the truck and engine??? I still think the Alternator is Bad but good to make shure you have good connec tions |
The Electronics are very touchey in these trucks and low Power will Kill FICM and Injectors stuff like that those are spendy so its Besst to get a Top of the Line Alternator and Battery setup it will payoff in the Long Run
Yes i have checked all connections.
have them bench test it BEFORE you leave the store
You see this at all times. The bad apple in the barrel.
I had an alt re-built for a Ranger I had because Ford did not have any yet too new (1988) So I had it done at a local shop that only does alt and starters. Well got it home and plugged it in and blew the headlights with too high of voltage. Turned out the new regulator that was installed was bad. So I would do what Daddykitty says and have then test it before you go. Sean :-drink |
I whent through 3 chain store alt's in 6 mo. :(
Originally Posted by jhinalabama
(Post 12227711)
FWIW this kinda stuff is very hard on the 6.0L electronics^^^^I see it all the time here too I have a china alt on my car but it goes at 1 per year so far but car dont have the type of electronics to damage the 6.0L does DC Power alternators are well worth it and its a HUGE Improvment over China CRAP https://www.dcpowerinc.com/ that Cheap China alternator IS very High Risk Gamble not worth it IMO |
so i purchased a DC Power alternator last night. the 185 amp one.Gonna take the chinese piece of crap back! Should have it in a week. Hopefully no battery light when i put her in.I'll keep you posted.Thanks for all the info!
sweet you made a very smart move going to DC Power
click my usser name and go to my pics go to the one marked dc power you can see the recomended wire upgrade you can make your own with fuse |
I read the pully is smaller than stock.Will i need a smaller belt? And this wire upgrade? Do I really need to do this or will it be ok just leaving the wires the way they are? How hard will that be to do? Not real good with all this electrical stuff!
You should have shims for the alternator, so the belt is the same.
If you are wondering about the wiring, then call the DC Power guys. But if they say you need it, then I would install it. Should be as simple as a piggyback wire for the 185A unit (I would think anyway). |
The DC power alt comes with shims to raise the alt up to compensate? Would like to see how this goes on install, whether you upgrade the charge cable. I am interested in doing this too.
heres a pic of my DC 190amp with the wire upgrade
https://www.ford-trucks.com/forums/p...ictureid=79328 and some more pics Ford Truck Enthusiasts Forums - BLADE35's Album: DC Power Alternator & Wire Upgrade I didnt get any shims with mine and it has worked just fine at all times with A/C on for some reason I thought the 250-270amp alt were the ones that need the Shims |
Originally Posted by BLADE35
(Post 12246088)
