1996 Crew Cab Short Bed 7.3l D60
I'm going to post this up, I may come down with sellers remorse and take the ad down as I'm back and forth on this, but we'll see....I've had the truck for 4 years and have put alot into it.
Here is the project log for more photos...Project OBS Crew Cab Short Bed - PowerStrokeNation : Ford Powerstroke Diesel Forum the highlights are: '97 D60 front with sway bar and trac bar Hard Knox Fab Works low lift RSK (within 3/4 in front of a stock F350 SRW truck) SD x-code front springs SD B-code rear springs with SD F350 blocks Hydroboost from '97 F-Superduty 140v modded SD IDM E40D has about 60k miles on it since local builder built it 4.10 gears with limited slip rear Pop-Up brand Gooseneck hitch double capacity rear fuel tank (capacity curently escapes me :doh:) '07 SD Lariat Power seats, they are gray with custom suede insets, rear has flip out load deck. Stock Aloca wheels, currently has 305/70/16 bridgestones, but they are about shot, I've got a set of 285 bfgs with about 25% tread I can put on. I also will include a factory 7.3 SD intercooler, a set of factory SD 7.3 pipes and a early '99 intake spider to do the intercooler conversion. It currently has 270k miles on it, when I purchased it it had 212k I think, carfax, showed the origonal owners to have put 196k on it and traded it in at the ford dealer in '99, 2nd owner apparently let it sit around alot, and then I got it in '08. When I put glow plugs in it last winter the injectors appeared to be all origonal, as all 8 were within 12 serial numbers of each other or so. Truck runs and drives good, I drive it everyday, it is a solid truck, but does have some dings here and there, and is starting to bubble up some rust over the rear wheelwells, I took pics of that as I don't want to hide anything. Let me know if you have any questions and I'm open to offers, but don't have to sell it either...clean title in hand... asking 10K Thanks, Justin 865-414-4576 https://lh5.googleusercontent.com/-o...3/IMG_0307.JPG https://lh6.googleusercontent.com/-h...3/IMG_0308.JPG https://lh4.googleusercontent.com/-f...3/IMG_0310.JPG https://lh3.googleusercontent.com/-6...3/IMG_0311.JPG https://lh3.googleusercontent.com/-j...3/IMG_0312.JPG https://lh3.googleusercontent.com/-k...3/IMG_0314.JPG https://lh3.googleusercontent.com/-D...3/IMG_0315.JPG https://lh4.googleusercontent.com/-s...3/IMG_0316.JPG |
It won't let me delete or edit the post, please delete, I'm not selling truck.
That's a smart decision. That is a beautiful truck with an awesome setup.
