97 f250 460 pcv valve help.
I've got a 97 f250 hd w/a 460. The PO was a real winner. The pcv valve isn't plumbed into anything and i know thats not right. I've got a bigger plastic vacuum hose coming from the throttle body going to the canister purge valve solenoid.
My question is, does anyone have a truck like mine with the screw in pcv valve that has a picture of the vacuum t that the pcv valve is supposed to run to? Or even a part number? I've been to the local salvage yard and have came up empty. I went to the dealerships around me and all they have diagrams of are the 5.0/5.8 and they haven't been any help for anything. Thanks |
It is a single vacuum line that, from your intake manifold, will run like this
Intake manifold (against firewall), 'T' at PCV, 'T' at purge solenoid, then end at the charcoal can under your battery. |
