NOS parts are addicting aren't they? A thin check book is the only way to combat the addiction.
You ain't just wolfin' there. I'll admit it can get pretty bad at times.
Consider this. Other than the fan blade, everything else I've pictured so far I can fit in two 12-gallon bins. I've got two Trans Ams, too. Both 1971 year with the 455HO engine. I've had them much, much longer than the 1966 Ford. Now consider now many NOS Trans Am parts might be in this many 12-gallon bins... http://i636.photobucket.com/albums/u...949EFDA561.jpg |
Is there any way of identifying an alternator to a particular era? The one off my truck looks like this. It has Motorcraft cast letters if that helps. Any numbers or codes to look for?
Pontiacs are crazy how many date codes, casting numbers and on the engine block and transmission are even partial VIN numbers. You can really run wild with the stuff. The hunt... http://i636.photobucket.com/albums/u...99091A9C12.jpg http://i636.photobucket.com/albums/u...99018EE0ED.jpg |
If I have more space I'd consider this one, but it's getting crowded here. Someone, go get it!!
1966 Ford F250 4x4 |
6k or 7k on the high side and thats a good price and i would ship it back here no problem..
a truck like that around here rotted out is like 4k or 5k.. and nice one like that original is 10k+ |
I just talked to my buddy (the one who drove the dump truck in the video) and he has been to see this one already. He says while it's not as nice as mine...not even close, to use his words...he thought it was decent.
Originally Posted by TA455HO
(Post 12490070)
1972: US Gov't forced FoMoCo to sell Auto-Lite as they claimed FoMoCo had a monopoly on autoparts. FoMoCo then started in-house brand Motorcraft, all the Auto-Lite part numbers became Motorcraft part numbers. Posts 132/135: All the packages introduced in 1969 (with a striker plate and parklight gasket FoMoCo envelope exceptions). 1969 introduced the 'running Mustang' on packaging. Circa 1962 thru 1968 cartons were marked FoMoCo, were blue & white with blue lines. Previous cartons were marked FoMoCo, were red & white with red lines. Hoses, etc marked Ford or Ford within oval would have been marked FoMoCo prior to 1969. CPR ~ Copyright 1966 appeared on parts packages well into the 1990's. |
(Post 12490070)
Pontiacs are crazy how many date codes, casting numbers and on the engine block and transmission are even partial VIN numbers. You can really run wild with the stuff. The hunt... http://i636.photobucket.com/albums/u...99091A9C12.jpg http://i636.photobucket.com/albums/u...99018EE0ED.jpg The backside should be the "teardrop" style like shown but will say Autolite instead of Motorcraft. The adjuster mounting ear also differs with a rounded version and a square version. For yours the rounded version is correct. They also had an ink stamping that gave volts and amps along with ID number, at some point they were also stamped in housing. 38 Amp which is standard for F100-250 would have a Purple stamp 55 Amp is Red 60 Amp is Green Think the 45 Amp is Orange or at least for the 42 Amp it was. I had the proper ink stamp but borrowed it out and someone cleaned it with Lacquer thinner and ruined it. |
Bill and Boss, thanks for the info. Exactly what I was after.
I was looking at some of these and see the ink stamp. Too bad they don't say AutoLite on the back anywhere. Thoughts? 55 amp autolite | eBay |
(Post 12495885)
I was looking at some of these and see the ink stamp. Too bad they don't say AutoLite on the back anywhere. Thoughts? 55 amp autolite | eBay You can do a correct alternator for probably 50.00 or less. Ebay listing is way way overpriced. I have always done my own. Gotta love all those NOS parts! I did same with my 427 F100 project found pretty much everything I needed NOS. Including grille, headlamp doors, all emblems, weatherstrips, lighting, dash pad, gauges and more. |
(Post 12495885)
Originally Posted by Boss9F100
(Post 12496327)
I have to re-think that now as it could be mid year 68 when they went to the Autolite~Teardrop. There was for sure a change but now the memory is slipping a bit when the teardrop was blank and when it said autolite. I know the adjusting tab changed from round to square but now cannot recall the exact date for it either.
You can do a correct alternator for probably 50.00 or less. Ebay listing is way way overpriced. I have always done my own. Gotta love all those NOS parts! I did same with my 427 F100 project found pretty much everything I needed NOS. Including grille, headlamp doors, all emblems, weatherstrips, lighting, dash pad, gauges and more. I stuff mine with NOS parts and at least for the TA a rotor and stator can be around $25 each, so doing it for under $50 with non import parts is hard to do if it needs those pieces. Here's a simple terminal kit in a sealed box that the guy wanted more than $50 for with shipping, and that's only about 6 tiny pieces. Needless to say, I didn't buy it. But, I do have a few of them already and they weren't free, either. Delco Remy Part 1846900 Package SEALED | eBay Here's a picture of some in various stages of completion. The open face ones upper left and lower right (let more air in, but also debris) are fairly rare style. http://i636.photobucket.com/albums/u...1DE88BB57C.jpg Insides of one that is almost done. http://i636.photobucket.com/albums/u...1E7157F2C7.jpg And here's a bin of NOS parts for the Delco alternators. Rotors, stators, bearings, brushes, regulators and even one back half end case. http://i636.photobucket.com/albums/u...1DF3392F57.jpg |
I just bought some nos ignition and door locks off ebay
Hey 1ton, glad to hear you made it through the storm. Yes, 'tis cool what all is available. Between eBay and the obsolete dealers...
Here's a few more I've come up with. Not sure these are all correct. Holler if something looks whacked. Horn button http://i636.photobucket.com/albums/u...36111F7C8A.jpg http://i636.photobucket.com/albums/u...361CD224E4.jpg Wiper motor gear http://i636.photobucket.com/albums/u...36510F10C2.jpg http://i636.photobucket.com/albums/u...36588A5A0B.jpg Vent window pivot springs http://i636.photobucket.com/albums/u...365F3CBBEC.jpg I've only found one of the pivots so far. Shout out if you have it's sibling. Should be mirror opposite. http://i636.photobucket.com/albums/u...366D2C9C1A.jpg http://i636.photobucket.com/albums/u...3672D1D4AE.jpg Glove box knob. I've installed it already. I think I'll get a new insert for my old knob and I'll have a spare. http://i636.photobucket.com/albums/u...3690F776E4.jpg http://i636.photobucket.com/albums/u...36986975EE.jpg These are apparently some pieces that hold the headlight bucket in place?? http://i636.photobucket.com/albums/u...36A9970C4D.jpg Rear? pinion seal http://i636.photobucket.com/albums/u...36B1341937.jpg One of the rear leaf U-bolt for the F250 4x4, but only if you have the auxillary overload springs like mine. Long dude!! http://i636.photobucket.com/albums/u...36BD701F99.jpg A replacement shock absorber for one of the Bostrom seats. http://i636.photobucket.com/albums/u...36D55582A3.jpg http://i636.photobucket.com/albums/u...36DC4C8DEC.jpg This is the drivers side front turn signal body. If anyone has a passengers side NOS that they want to part with I'd be interested. The drivers side has a ground wire on it that you can see that the passengers side apparently doesn't have. When I first saw that one my truck I thought for sure someone had added that. http://i636.photobucket.com/albums/u...36EDFB515B.jpg http://i636.photobucket.com/albums/u...36F67CDFBE.jpg What I *think* is a correct emergency flasher harness. http://i636.photobucket.com/albums/u...36FFD39202.jpg http://i636.photobucket.com/albums/u...3707A4F569.jpg Here's that engine wiring harness. Only difference I could find in the wiring was the extra red wire to the right of the picture. It's plugged into itself and taped together. http://i636.photobucket.com/albums/u...370E1A6E6E.jpg http://i636.photobucket.com/albums/u...371471BC77.jpg Oh, and it says SX instead of SX-L http://i636.photobucket.com/albums/u...371A65A611.jpg Here's the headlight harness http://i636.photobucket.com/albums/u...371FC4C1AE.jpg And the taillight harness. This harness, like my original, has a fabric covering over the top of the tape that is interesting to look at. Makes it looks more like a rope than a wiring harness. It also has a metal ID tag on it with the part number and a FoMoCo logo. http://i636.photobucket.com/albums/u...372565F24D.jpg Battery hold down clamps. http://i636.photobucket.com/albums/u...09765AF35C.jpg http://i636.photobucket.com/albums/u...0980A9EB8E.jpg Tailgate hinges repainted Wimbledon white in a PPG Concept single stage with a 2K epoxy primer. I used the darker background so they would stand out better. http://i636.photobucket.com/albums/u...8F51FD21B1.jpg And finally, here's a couple of shots of the engine after I've cleaned off most of the gunk. http://i636.photobucket.com/albums/u...372EC90547.jpg http://i636.photobucket.com/albums/u...373763CA16.jpg In that last shot it looks like the engine was painted on its side and then rotated upright before it dried and a big run from each freeze plug ran down the block. |
Storm was fun... seeing 3ft of water on the main rd running thru our town
