Trans temp gauge acting funny?
I've noticed my Trans gauge spiking several times as I drive. The check gauge light comes on then goes off. It is not throwing any codes. Anyone had this problem?
Yes, several people have had this problem. It's either the transmission fluid temperature sensor or the wiring to the sensor inside the transmission.
If you had a Digital Gauge the Temps might shock you
Mine hits 8129* a 1mile after i leave the house after a 2 day cold soak then settles down when fulley upto temp If I drive it everyday No Issues |
