Power steering pump boils fluid
If I have your interest, I have a problem. Long story, but I am trying to use a ford pump to power a Hydro-boost off a diesel pickup, took everything off same truck. Started it up, ran ok for 5 mins & PS pump fluid boils. No PS box in the system, just the Hydro. Seems like the fluid is not getting out of the pump & circulating either. I figure a blocked pump discharge or blockage in the Hydro. I can shoot air backwards thru the hydro, too hot to touch the pressure side. I had the outlet nut off the pump, could I have blocked the discharge when I put it back?
Tks for any help!! (PLEASE!!) |
What did you do with the line that would have gone to the PS box?
Unlikely it's boiling more likely it's getting airated. Could the pressure valve in the pump be blocked? |
Boils
Got it figured out, hydroboost was stuck. Line out from HB goes to return on pump. No boil now, but lines get REALLY hot, too hot to touch even the rubber part. I'll put in a cooler ASAP, but do you have any idea how hot is OK? I have a temp gun & will check mine.TKS!
Originally Posted by sibernut
(Post 12164491)
I'd figure about 200 degrees is a high limit. The HB doesn't need much flow and the pump is always pumping. It has an internal pressure bypass to control it. Your likely much better off sevely underdriving the pump or just plain using a smaller one. What is the application, how is it working out? |
NOW we're getting somewhere! I routed the HP line formerly to the steering to the return nipple on the pump, tee'd in with the (I assumed) relief line, the one w/ the low pressure type nipple on it.
Before I forget, the HB is installed on a 45 degree angle with the connectors DOWN, in other words 180 degrees from normal. I realize this may make bleeding difficult, but the ports are all on the high end I am using this setup to power a hydraulic clutch master cyl on a semi, the clutch was getting impossible to push in. It's a Volvo, they come standard with this hyd clutch setup. I had to flip the HB due to clearance issues. I'll go out & block the pressure type line out & see what happens tonite, also check the temp once running. You can use "paladin_ron@yahoo.com if you'd rather. We are leaving in a week for a vaca using this truck to pull a big RV trailer, I'm a little stressed to get it working right now. Tks for the replies!! |
(Post 12165536)
(Post 12165536)
The truck I can only assume has PS why aren't they one system?
(Post 12165536)
Volvo semi is stock w/hyd clutch. Didn't want to attempt running it off the truck system, VolvoTRW said 2100 lbs pressure & Ford said HB runs at 1250 max.
I don't think the pump is running that fast, 2000RPM max on the Cummins in it & pulley ratio looks very close to 1:1 w/ the crank. I'm driving it off an empty pulley w/a serp belt |
