6.0 Stalls when turning left, and cuts out over bumps
Our 2005 Ford Powerstroke E-360 6.0 family van recently started cutting out over bumps going down the freeway. It returns to idle for a second, and then runs again as normal. This only happens when there's a bump or series of bumps in the road. Numerous codes are on, including both the camshaft and crankshaft sensors, EGR, etc. It's all stock except for a tune. Turning left, it totally quits sometimes, especially if you turn left and hit a slight bump. Runs fine turning right. Any help would be greatly appreciated!
Check your wiring harness.
Thanks for your response. Any parts of the wiring harness in particular? We removed and Dialectic greased all the connections we could get to this morning, still the same problem...
- just read posts on here 6-23-12 about shorting out of wiring in the steering column. Sorry i can't refer you directly to the thread or posts, but it was causing the truck to quit entirely, suddenly. I think the story was that a tech at a dealership found it or knew about it already when the poster had truck towed to dealer.
- I have noticed, after removing the air bag from steering wheel and modifying the wheel, that the key can be left in without the beeper going off, and the door won't stay locked-as if the key is in ignition when it is not, after working on the wheel. A short when turning the wheel sounds like a steering column wiring short, no? |
Moved to the 6.0L Powerstroke Diesel forum.
Did you find the problem?
6.0L stalls on turning left, on bumps, etc.
Originally Posted by AGE mechanic
(Post 12002756)
Bump, same issue 2003 F350 SRW .. 6.0 Diesel
Originally Posted by Asphalt_Cowboy
(Post 11988174)
O'Rilleys Pulled Codes
Originally Posted by TreyD
(Post 18855148)
Same issue, only left turns while moving. Not at idle. Also does when traversing ruts. Changed fuel filters and bled water from fuel separator... stumped, how did @Asphalt_Cowboy fix it?
P2614 - Camshaft Position Signal Output Circuit / Open P0401 - Exhaust Gas Recirculation Flow Insufficient Detected Ideas? Thanks T |
Check FICM and IPR wiring.
Still got issues dies or stutters turning left
Originally Posted by bismic
(Post 18857797)
original issue, dies while turning left at 3mph or 75 mph so, I replaced the IPR and the IPC ran fine for a few days then hard shut down, no start no crank turns out the ficm plug melted... and burnt a few pins in the ficm I replaced plug and ficm truck worked great for a week now, out of the blue - same crap dies or stutters with left turns not right not as bad as before but fear it will get worse with time so, now thinking a short on the wiring harness where do I start or what do I start to look?? thanks t https://cimg9.ibsrv.net/gimg/www.for...4e868328e.jpeg https://cimg6.ibsrv.net/gimg/www.for...260d54e97.jpeg |
Have you checked for codes (DTC's) with a very thorough code reader?
As you found out, the FICM and wiring (harness) is a common area to cause your issues. Since you found the evidence of electrical shorting, it may be that simply replacing the connector and the FICM didn't address the root cause. Look for chafing in the FICM harness - check back to the PCM and check the harness to the injectors. Also, look for harness chaffing in the IPR and ICP wiring. You can even try running for a while w/ the ICP sensor itself disconnected. Doing the wiggle test might help also (while idling, wiggle as much of the Engine Harness, FICM harness, Injector harness, etc as you can trying to get the engine to die). Also, is the plastic wiring shield that runs across the width of the engine compartment drooping down and touching the top of the turbo? Just as an fyi - One of the first things to check when an engine dies when turning is the fuel level. A fuel tank level at or below 1/4 tank might cause a stall when turning if the pick-up tube is broken. This is by no means a complete list - many wiring issues are a pain. I'll change the text to red for some that would seem to happen when turning. Wire Chafing Locations (Closely inspect wiring when you have injector DTCs): https://www.ford-trucks.com/ford-man...re_chafing.pdf
New injector harness, new FICM, and check the wiring and pins at each injector visually and with a meter for shorts before installing a new FICM.
Your FICM "C" connector burnt across the ground and power-in pins, which would indicate a serious short. The injector harness s relatively cheap compared to burning up a new FICM, so for me it's a worthwhile investment. The turning in one direction has a history with me. Mine died every time I made a hard right no matter the speed. It cured when I replaced the main harness, but that never caused the intense burning of any of my FICM connections. |
Based on the fact that you changed out the plug and are back to the same issues, it would seem likely that the issue is in the harness feeding the injectors. There are four wires that feed each injector. It doesn't take much to cause an issue.
