banjo bolt crush washer question
I pulled the banjo bolt to pull the fuel pump. There was only one crush washer on it, but the kit i bought from Riffraff came with two of them.
Do I use both or just one? Which way do they go in? |
There should be two. Just did this one my truck. One goes by the head of the bolt, the other between the collar thing and the fuel pump.
I'm sure you already have, but just in case... double-check that the second one isn't stuck on the banjo bolt fitting. Mine was pressure-welded on there pretty good.
Originally Posted by 07Wolfie
(Post 11986012)
Just went and looked and you where spot on thanks. |
