1992 F250 no spark
Hey guys and gals!! I have a 1992 Ford F250 5.8L gas engine, with no spark so far I have tried a ignition Control unit ( the one on drivers fender ) and a coil, still no spark!! What else can I try? need to diagnose not just throw parts at it!! please help!! thanks
These pages may help you to isolate your no spark, could be a bad PIP
Part 5 -Ford Ignition Module Test. Fender Mounted Module (ICM). |
X2 :-X22 That is a pretty good writeup
Does the fuel pump run when you turn the key? Have you checked the fuses both under the dash and under the hood? If that all checks out then check for voltage at the coil, should be 12v IIRC on the 'hot' side of the coil (the side the DOESN'T have the condenser/noise filter hooked to it).
Originally Posted by Slip ford man
(Post 11950727)
Originally Posted by pfogle
(Post 11951479)
(Post 11950727)
Originally Posted by lilsuzuki4x4
(Post 11960111)
ok i did all tests, and did them 2 times to be sure, as per the test it point to the PIP sensor. Where is a good place to buy one and can you get it out of the distributor? or replace whole distributor?
I had terrible luck with the re-manufactured units, so...I went to CarQuest and bought a brand new unit, marked on the box "heat tested" I think it cost me 120.-... |
ok got a used PIP sensor, and I have all kind of spark, but still will not start? I double checked timing? suggestions please?
What about the question from pfogle above, can you hear the pump for a second?
(Post 11962667)
I must be off in timing, any one have a how to find TDC cylinder # 1?
where should the timing mark be on the harmonic balancer on comp stroke? #1 cylinder is pass side front? Sorry guys i should get a service manual for this truck |
(Post 11963924)
yup! and I replied 06-15-2012,post #6 02:07 AM look above
I missed that Fuel Injection Technical Library » Setting the timing |
(Post 11964595)
I missed that
so it was PIP sensor, now next days off set my timing and hope she fires
