93 F350 4x4 gas front leaf spring code
Almost ready to do my dana 60 swap, just need new leaf springs. Anyone know what code they are? Thanks
Anyone????????
Check these codes by your Vehicle Certification Label.
http://i11.photobucket.com/albums/a1...pringCodes.jpg |
Thanks but I have a f250 that i wana put f350 front leaf srings in
There are at least 3 different spring codes
small block big block/diesel cab-n-chassis |
Then I need small block ones
are your springs shot my 250 seems to have the same springs as my buddies 350 ( both crewcab diesel)
Originally Posted by joshh
(Post 11945037)
ok not saying ur wrong but what is the differnce? im curious now
F250 springs are arced downward and have a HIGHER spring rate than the F350 by around 1200lbs
YES the F250 has a HIGHER rate spring. It is due to the PIS POOR Design flaw of the TTB and how it makes the leaf spring flex in ways they were never designed to |
intersting guess mine are just sagging then look to have same arch as his
also on that note wouldnt the op be better off keeping his stock springs for the swap |
(Post 11945423)
also on that note wouldnt the op be better off keeping his stock springs for the swap No, the rearched F250 spring have such a High rate they will give a kidney jarring ride and will sit Lower than A F350 |
nevermind my dumb comment i read ur post backwards thinking u were saying the 250 had more arch making it sit higher
was long day guess i should of went to bed instead of posting last night |
When I converted my F250 to the Dana 60 front end, I went to a local leaf spring shop in Baltimore called Middleton and Mead, they showed me the catalog that had the different available springs, there was no distinction between small block, big block/diesel or cab and chassis. The aftermarket springs were divided up between F250 and F350 with each category having 4 different springs available, all depending on the spring rate that you needed. The different springs had a different number of leaves in the pack.
I ended using a 2 ply F350 spring then having them de-arched about 1.5" so that the truck wouldn't be jacked up in the sky, they matched very well to the new rear springs I installed a year earlier. Do yourself a favor and call a reputable spring shop and talk with someone who knows what they are doing instead of being mis-led by the interweb know-it-alls that seem to lurk on this site. :-X22 here's a link that has some decent listings for front leaf springs. www.sdtrucksprings.com |
Originally Posted by firewood truck
(Post 11948749)
I ended using a 2 ply F350 spring then having them de-arched about 1.5" so that the truck wouldn't be jacked up in the sky, they matched very well to the new rear springs I installed a year earlier. Do yourself a favor and call a reputable spring shop and talk with someone who knows what they are doing instead of being mis-led by the interweb know-it-alls that seem to lurk on this site. :-X22 here's a link that has some decent listings for front leaf springs. Leaf Springs, Helper Springs and Suspension Parts | SD Truck Springs Ford didnt just put a different spring code on the door jam sticker for the hell of it. They all have different weight ratings. As for the 2 or 3 leaf deal. EVERY f250 and F350 left the factory with only 2 leafs. The aftermarket came up with the 3 leaf deal for the extra weigh of plows and winch bumpers. I have been working on these trucks for over 20 years, I am NOT an internet know it all. The level of my craftsmanship and the NUMEROUS truck I have built should more than attest to that |
