Plugged Bad Cat, I think?
Hi all
Been a busy boy and have put a ton of miles on my E lately. I just had the E-test done and I just squeaked by. I am down on power and have a slight hesitation/stumble when I accelerate. Mileage is down too! Plugs and COP's were done just over a year ago with Motocraft plugs and eBay COPs. I have new plugs ready to go in and will check the COP's when I get them out. I think the Cat is done and wonder about replacing it. I really like the Magnaflow Cats, they work great on my Stang. Any input here? |
I'd replace the O2 sensors first. Easier and cheaper and if they haven't been replaced they are due. How many miles on the van?
I have only heard of a cat pluging up if the engine runs way rich and the cat overheats from all the extra fuel it has to burn and the matrix breaks down from this overheating. |
200,000 miles and climbing.
Good idea changing the O2 sensor. Will do. |
Are you seeing any codes on your scanner? 02 sensors should show something if failing or running out of spec?
No codes. But will double check during drive today.
I was always under the impression the O2 sensors would trigger something---my Actron scanner has a mode to check just the emissions system components----you're running a ScanGauge?
On my last van a plugged cat caused a valve to drop and grenaded the engine..It was a 300-6 on propane to boot....and as far as O2 sensors go they should set a code when they fail ....
