Spare tire key cly. in bumper under cover
Hello and i hope someone can point me to the right place to get the part i need ..
I have a F150 2006 reg cab and i need the cly key thats just under the little cover door on the bumper . mine has rusted out and need a replacement .. i dont wont to just leave the hold there because it looks bad .. PLEASE can some help me to find this . Thanks and happy trucking |
it uses the ignition key to open it, so i would guess you need to go to your local dealers parts counter.
otherwise go to a junkyard and get the lock and the key to open it |
Mine has seized up on me about 3 times. I recently was able to pull it off after putting some penetrating oil on it and then some pliers to wiggle it free. Once I got it out I took the keeper off (looks like a C) and sanded down the cylinder. I don't have any but next time I'm out I'm going to get some rustoleum to coat the exposed surfaces to help fight the corrosion. Not sure how long that will work but it's gotta be cheaper and easier than finding a new one and matching it up to your ignition key.
Good luck. |
I have found that if you clean it in fall and spring it works well by that I mean
remove and clean it with wd 40 dry it put in bumper and coat it under bumper with derilect grease coat the back of the Key lock till all is covered. It will stay on this keeps the water out of it. I also drop and clean spare tire and clean the fuel mod. on the x member under spare. 5 winters now and all working Ok. |
Thanks ill look into it very soon .... just took off cly and have to get a new one does anyone know the price and if it will come with new key?
Thanks |
