Washing underside of truck what should I be careful of?
I live in a mountainous region where we get a lot of snow and because of that the roads get salted a lot. I want to give the underside of the truck a good washing this summer to wash away all the salts and road grime. I have never done it before and I want to be careful not to harm something I shouldn't or put water or soap somewhere it should not be. I have a pressure washer, would it be safe to use it? What kind of soap to use? Just regular Meguiars wash shampoo?
Thanks |
I think the soap should be fine regardless of what you use. I would try and be careful around the rockers. The plastic sill plates in the cab just clip into the floor, and with a pressure washer you might blow that sill plate up and inadvertently fill your cab with water
Personally, I think the pressure washer is overkill. A good thorough spray down with a typical garden hose and a nozzle should be sufficient. Be most careful of the engine bay.
Great tips, I'll forgo the pressure washer and just scrub everything down with some soap and rinse with a high pressure spray nozzle. I will pay extra attention when I'm under the engine bay.
Thanks a lot guys :-X22 |
in your manual it says to cover the battery, alternator, and intake opening only. I power wash my motor all the timejust to keepit looking new with a 2200 PSI washer. I spray everything with bleachwhite, then scrub it all with a soft wheel brush and then rinse, never had a problem with COP, or plugs. Undercarriage i just wash real good with the garden hose
Originally Posted by SuperDutyScaler
(Post 11873540)
Some carwashes have high pressure underbody wash at the start. Use it, you're done.
Originally Posted by Papa Tiger
(Post 11873948)
(Post 11873948)
Put a lawn sprinkler under it and VIOLA!
I have more problems with bugs on the windshield and grill. LOL
(Post 11874759)
Now if I can only get the grandchildren to stop throwing rocks into the bed of the truck and behave better? LOL
Originally Posted by critterf1
(Post 11874424)
I love this idea awesome!! |
I power wash the underside of my truck once a month and I've never had any problems. It's not any different than driving in the rain.
