synthetic or plain fluid
I need to get the trans fluid and filter changed in my 03 expy xlt 4x4 with 82,000 miles. should i go to synthetic or just stick with regular ? i would like to go with synthetic, but it is pricey !
Originally Posted by duffin
(Post 11857296)
Isn't mercon V synthetic
Drain, flush, change filter, and refill with the recommended fluid only. It should be on the trans dip stick.
My Expy is at 297,000 miles. I still use the mfg recommended fluid.
I change out my tranny fluid every 50k although the mfg recommends every 35k. Since I only empty the pan and change out the filter, I don't get the converter emptied. I know that means I only change about 50-60% of the total fluid per change but feel it does the job and decided to not go synthetic. So far, so good. Knock on wood. |
My '06 F-150 just turned 50K and I changed the filter and gave it a full flush yesterday. $90 for 16 qts of Valvoline Mercon V and $20 for a Motorcraft filter. Flushing is very easy if you have the right stuff (large 20 qt pan, 3/8 " ID clear tubing, and a few extra rags) and I always get 2-3 extra quarts for a clean flush. It takes about a half hour, so it's a 2 beer job :-drink
Originally Posted by lv2race
(Post 11859967)
Is there a drain plug on the converter that I'm not seeing? |
Originally Posted by r2millers
(Post 11864229)
LV2race,
LV,
Sounds like you have quite a system. If it's the return line removed, are you empting the tranny cooler or the converter in that minute or two? Do you feel like you have completely replaced all the tranny fluid? |
(Post 11876512)
LV,
I just use what is recommended by the manufacturer. But then I service the transmission more often than most people do. Clean fluid is better than expensive, burnt, and dirty fluid.
