Ford Truck Enthusiasts Forums
-   Vehicles for Sale (https://www.ford-trucks.com/forums/forum233/)
-   -   1972 F100 4x4 Parts truck HOUSTON,TX (https://www.ford-trucks.com/forums/1162157-1972-f100-4x4-parts-truck-houston-tx.html)
texaskid22 05-15-2012 08:56 AM
It runs and drives but does not stop. I drove it threw all 4 gears, engaged the 4 wheel drive,the 360 has no smoke comes from the tail pipes, engine runs but the 2 barrel carb needs accelerator pump repair. it has solid front axle with functional locking hubs. the transmission is a t18 i believe, not sure what axles it has or the lift kit. the transfer case shifter just says 2WD and 4WD.
the cab has cancer in the floors and the bed floor is almost completely gone. rust on cab corners. does have rear sliding window though. power steering works but is weak with the tires (36'' i believe). it does have a clear texas title. heater works, some lights work, wipers dont work. I will try and get more pictures.
texaskid22 05-15-2012 09:32 AM
http://i50.tinypic.com/j82zjb.jpg
http://i47.tinypic.com/abmu0x.jpg
http://i47.tinypic.com/28vzksl.jpg
http://i47.tinypic.com/2ed1qih.jpg
http://i47.tinypic.com/345k4dt.jpg
texaskid22 05-15-2012 09:51 AM
832-305-3154 call or text.
moneypit72 06-01-2012 09:10 PM
816 263 2665 call or text if its still available please
© 2018 MH Sub I, LLC dba Internet Brands
