replacement of oil cooler and what else?
2003 93k eot 224 fwt 186. After 20 min run at 70mph on flat ground. So looks like oil cooler replacement. I will also be doing a egr delete & Blue spring upgrade. Anything else while its in shop? This truck is about to break me! But she is still cheaper than a newer one! Its a love hate relationship for sure! Lol
stc fittings and studs if you can afford it
Studs are outa price range im sure. Stc fittings I thought those were problems for 2004 and newer 6.0?
I believe you can still do them on an 03 but I could be wrong. Banjo bolts might be a good idea
no stc fitting on an 03. also banjo bolts are a waste of $5
Thanks cheezit! Am I on the right track with oil cooler and egr? I honestly am not concerned with studs since Im not going to tune, and my camper is only 6k fully loaded... on the sgii all other readings are g2g as from what I have read. Im going with the egr block/weld is that a good option? My new mechanic quoted me a little less than 1k for oil cooler and egr block/weld. He is also going to clean turbo & intake. Does that sound right?
How about a upgraded turbo oil line and upgraded turbo drain line.
Originally Posted by Randy777
(Post 11814284)
Well thats Fine BUT being a 2003 the really early ones had a Snap-to-connect Turbo oil supply line instead of the Later Bolt connection oil line If you have the Snap-to-connect turbo oil supply line then you must get the updated oil cooler Housing that will receive the bolt Look at my truck build date in signature It was like a Week prior to the build date of my truck they started installing the bolt one this^^^^^is the reason I know my truck Build Date:-X22 |
Install some Fumoto Valves on the block for draining later. Send in your FICM to Ed @ FICM repair while its down and have him upgrade it for you.
and yes 1K for all that is a good deal
I was quoted 1200.00 at the dealer just for oil coooler replacment 1 year ago Just make shure he TIG welds the egr cooler as its Stainless Steel anything but tig weld will eventully break from the Hot/cold cycles And also remember your 2003 has the Round EGR Cooler and there the Good Ones so you could just leave it alone I choose to Egr Deleate as there is alot more Benifit with a Deleate I gained atleast 1mpg and the sensors in the intake stay clean now and the Biggie is it CANT FAIL if its GONE Make shure you flush cooling system really good I suggest you do it as most shops dont have time to do multiple flushes some of these trucks need give it VC-9 cleaner the works reverse flush every thing stick a hose in it Just flush its GUTS OUT Put a Coolant filter on it and change the thermostat I did everything mentioned and my 03 has been Good since And MAke SHURE they leave the EGR Valve installed and plugged in for fan operation and to keep PCM Happey |
Originally Posted by BLADE35
(Post 11814547)
this^^^^^is the reason I know my truck Build Date Probably can add that to the "You might own a 6.0 if ...." thread. If you know the exact day it was built you might own a 6.0. |
Originally Posted by Piolet
(Post 11814591)
Mine rolled out of the Kentucky plant on Thursday Feb 20, 2003.
Probably can add that to the "You might own a 6.0 if ...." thread. If you know the exact day it was built you might own a 6.0. So you should have the snap-to-connect turbo oil line???? |
I believe I do have the original flex line. I think that is the stc one??
I know mine is june 03 that's it how do you find exact day? And yes icp is under turbo... lol That's my thoughts on the egr too if its gone it can't fail! Thanks blade35! Any more advice? So far I have done turbo, 5 & 7 injectors and I have started replacing all fluids. I run 10w30 rotella which I will be going to 5w40 with next change. Oem filters across the board. Thanks again to all who have replied!
I gave the dealer my Vin# in parts department they gave me the build date
