Originally Posted by Knothole
(Post 11807373)
I like this idea: https://www.ford-trucks.com/forums/1...nch-mount.html
Originally Posted by RussF350
(Post 11806288)
OK, thanks for all the advice. What about this idea. Can I mount the winch to my receiver then just run jumper cables from the battery to the hitch whenever I want to use it? I will be using this maybe once a year, I just want a winch option in case I ever need one. I'm not talking about $12 Kmart jumper cables, I have a pair of heavy duty all copper cables, they cost me $80.
-Mark |
I agree with mark and others in as much as I would only use jumper cables for an emergency and only for a short time. The clamps can cause sparks which can cause a battery to explode. The clamps themselves will tend to get hot and could damage the post as it melts. :-hair
Instead of running long pair of jump cables, how about a separate deep cycle 12V battery in the bed and wire it onto a battery shut off switch used on RVs. Charge the battery about once a month.
Originally Posted by arctic y block
(Post 11807659)
I've had to winch my dually out of the mud twice (2wd) and this worked fine.. we used a suburban as the anchor, and the winch was mounted on the dually. my wife loves to rave about who saved who (a chevy family girl). now have 4x4 so this shouldn't happen anymore! sam |
Ya I have done it also Sam, But S--t happens. And when ya least expect it. I have seen a battery blow up in a mans face. I grab him and pulled him out the door of the shop, knocked his ball cap off and hosed him down with in 15 seconds. He was still scared for life where his hat brim was. Just saying;)
Originally Posted by sdetweil
(Post 11806494)
I used Anderson quick connectors for the 4 gauge wire to the battery box. (kept charged via solar)
Battery and Cable Connectors - Wire Connectors - Grainger Industrial Supply(CCSB) Sam Warn, Ramsey, and others have portable winch kits, carriers, etc., and the highest I have seen any of them rate them is about 9,000 lbs. I suspect this is due to the rating of available receivers. I also think that most receivers have a pretty low safety factor, and I would be hesitant to go over that in anything but a straight line pull. A hitch will not see 10,000 lbs of force from a 10,000 lb trailer. |
Originally Posted by David N.
(Post 11808959)
The best I can tell, those are the same connectors Warn (and maybe Ramsey) uses on their QD's for their portable winch setup.
An angled pull does not bode well for the trailer hitch or the level winding of your cable onto the spool with a load on it. Personally having seen all kinds of incidents in 30 plus years of wheeling my personal stuff and doing really heavy pulls (70 + tons dead weight with a mire factor of 3) with the Army equipment (ok yes tanks and bigger heavy tracked Recovery vehicles) I tend to err on the side of caution.
Do as straight a pull as you can, your other weak spot is your hitch pin holding that cradle and winch in the hitch receiver. Happy motoring. -Mark |
All good advice Mark. I am at 60 years. And most of that was being involved in some way of logging. Now this takes some of the heaviest winching man has ever produced. This in the Great Northwest and Alaska. Also next to the Redwood some of the biggest timber in the world. And several years operating accident recovery equipment. No freeways here. It's down in the hole somewhere and ya got to go down there to find it.
So yes, Sage advice for being safe. Guys think about what you are doing, than visualize the worst case scenario. Like what could go wrong if I do it this way. Than re hook to the straightest pull with as much lift as you can get. Reps to the guy that brought up safety. I have packed out plenty of dead loggers that simply just got in the bite. And died for it. A few times we had to make two trips to get both halves. A wire rope to flesh is like a hot knife to butter. Again, Happy Wheeling Guy's :-hijacked:-jammin |
I have an 8000 lb mounted to a reciever hitch winch mount,I have 2 gauge wire run to both ends of the truck,with a main disconnect at the battery,with welder twist locks on the cables works well.
Originally Posted by skip mitchell
(Post 11812702)
Like what is this on? Where did ya get the receiver and what make is it? Come on Man. Inquiring minds would like to know.:) At least this inquiring mind would. |
I would use welding leads. Quick connect ends and run it to the front and back. Why risk burning out a $500+ dollar winch and damaging your truck over a few bucks. Spend it wisely and it will pay you back ins trouble free service
Welding connectors are heavy and allow for costly mistakes. Those forklift electric plugs come in different sizes and I think go up to 400 amp, while they have light and foolproof design. I bough mine pretty cheap on ebay..
That is more or less what I was thinking. We've used them for welders on service trucks. Never had to buy them though
