mnkeeking |
05-06-2012 11:46 AM |
Finally think I figured out '68 F100 backfire
First, thanks for all the help, advice and encouragement. Second, I'm thankful to have an understanding wife. So I've been trying to diagnose and repair a backfire thru my carb on a swapped 460 motor in a '68 F100. No matter what I did, rebuild the carb, replace the entire fuel system, work with the ignition in every possible combo and degree angle, I STILL have the popping noise in my carb. VERY frustrating. Yesterday I was about to start smashing **** when I remembered a trick my dad taught me years ago. With the motor running I began taking one plug wire at a time out of the ignition sequence. Every other wire I took off would make the motor bog a bit, but otherwise run ok. When I took the #6 wire off there was no change in the motor. I also revved it up to about 2000 RPM. No popping, ran strong, had that nice deep growl at high RPM. NO POPPING. Then to check the plug wire I switched #6 and #7 wires. #7 cylinder ran fine with #6 wire, #6 cylinder with the #7 wire still had the popping noise, so the wire at least is good. I did not check to see if the #6 plug had spark as the motor was too hot. Additionally, the day before I ran a compression test and ALL 8 cylinders had good compression and were within 5-10 pounds of each other. Anyway, I let the motor cool down yesterday afternoon, and removed the valve covers. Here's what I found: #5 intake rocker arm is very sloppy. Almost enough slop to get my little finger between the end of the rocker arm and the end of the valve stem. #6 exhaust rocker arm had even more slop. Without tool measuring the rest of the valve train, just going by feel at this point, I found that most of the rest of the train is snug and when I measure it I'm sure it'll be within tolerances. Felt a couple that were not quite snug and plan to measure all. Pushrods were not micced but rolled out and none seem to be bent or out of round. My motor does not have adjustable rocker arms.
Seems to me that on the #5 and #6 cylinders the valves are stuck closed because the pushrods are not long enough to do their job. I also reckon that would cause the popping noise I can't fix by adjusting ignition or fuel systems. Ran good if #6 cylinder was taken out of combustion sequence, but a comp test shows #6 has good compression.
I ordered a few longer pushrods to replace in the sloppy spots and standard length pushrods to just replace them all in any instance. What are your thoughts on replacing lifters at the same time? Most of the rest of the valve train parts are functioning as they should, but since I'm gonna be in the general area, I'm giving it some thought. Another aspect of this motor is that my early goal is getting it and the tranny mechanically sound and reliable. I'm retired and have plenty of time. Once I get it mechanically good to go, then the next phase is performance, paint, interior, chrome, etc. If I have to pull the motor apart for performance purposes, I'm good with that, but for now, I want rock solid reliability.
Thanks,
Joe
