TTB, camber is maxed, still lots of positive camber
Hello,
the previous owner installed some really tall springs in the front end of my 350, and i noticed it has camber bushings, but they are maxed out, and its still sitting with a lot of positive camber (feels real bad in corners man!). Ive read that you can buy 3 degree bushings or 5 deg bushings. Im hoping this thing has 3 deg bushing kit and i can swap in a 5 deg. Lowering the front is not an option as a) dont want to dump money on springs as im saying for a 4wd conversion b) i like the jacked up look (now just need to bring the rear up) so-what is the most cost effective way to get neutral or 1/4-0.5 degrees negative camber or whatever stock calls for?? |
Hmmm...
Sounds like the 5* camber bushings are your only option at this point...Or shorter coils... |
ive heard of some shops bending the control arms.....dont know if i like the sound of that..
Brackets that drop the pivots down. I believe they should have come with the lift kit. Maybe you can get them separately from a lift kit manufacturer?
^ any links for that please?
im all new to this especially this TTb nonsense. wondeirng if i could fab up some kind of bracket at home that would correct my situation? |
