4.6 spark plug options........
2001 F-150 4.6 am doing 50,000 mile maint. had some transmission fluid issues so i figure while i'm at it.......question
is does anyone have a pref. between NGK or Bosch,or are they about the same. i have heard the "exploding"/Vibrating loose plug issues and so i thought i would ask the forum. also have been looking into warranty specs,and i am not sure if i am going to have an issue with either of these or not yet. just seeing what works for you guys.....Thanks.....Dave |
NGK or Bosch?
None of the above.....Motorcraft is what I would use :) |
I agree, Motorcraft double platinum!!! Autolite is basically the
same plug, both are made by Honeywell..... |
Thanks guys,well give it a try.....Dave
as stated above, my vote goes to motorcraft/autolite . And dont forget the plug wires. Expensive but i used genuine motorcraft for my replacement wires.
