Transmission not shifting properly
Transmission will not shift into 2nd gear until it reaches 30-35 MPH, and even then you have to get off the gas for it to shift. The engine is a freshly overhauled FI 302, so I dont' want to stress the engine till it has had to break-in. Any help would be great.
Can't offer any assistance. No clue what transmission it is. We don't guess 'cause we'll give you bad info. Please tell us everything that is going on, like what transmission, how long it sat w/o driving, and any mod's you've done to the tranny.
(Post 11767946)
If we don't know what it is, we can't help you. A fuel injected 302 doesn't tell us whether or not your 302 came with a C4, a C6, or an Automatic Overdrive. If it's a C4 or a C6 it could be the modulator valve or the way the vacuum lines might've been (incorrectly maybe?) installed. If it's an Automatic Overdrive, you might need to adjust the linkages that control the shifting of the transmission (and also serve to keep the transmission from burning itself up). If you know what transmission you have, tell us. If you don't, you're going to either have to tell us the transmission code on your door jamb sticker, or you're going to have to get up under there and count transmission fluid pan bolts to tell us. Let us know what you find and we can help. |
Agree, I will check it tomorrow and get back with you all, the truck did sit for over 3 years
Originally Posted by chato86f150
(Post 11768218)
But, the thing about sitting, which I suspected, is likely a big part of your problem. I'll save my response to that until you report back with more info, but please tell us everything and then some. We'll discard the irrelative bits. |
It says automatic overdrive metric, it has 14 bolts, it's shifting now after a good drive, but it stills shifts hard, and it seems to sprudder also, doesn't have the power you think a rebuilt engine would have. Any advice on how to get it have more power?
AOD tranny. Since it sat for over 3 years you have varnish or somesuch in the passages. I had a similar problem on a C6 and cured it by putting half a bottle of Sea Foam Transmission stuff in it - and then drove it, and drove it, and drove it. Took about 500 miles to completely straighten out.
As for the engine, you are back to doing the "please tell me the answer without any clues" thing again. In order to discuss power we need to know what gear ratio you have, what tires you are running, and what's been done to the engine. Further, you will need to pull the codes from your computer as it'll tell you if anything is wrong. Here are a couple of links on that: Pull Codes 1 Pull Codes 2 I'm sorry if I sound gruff, but you don't seem to get it very quickly. We want to help you, but we cannot give you decent answers without understanding the problem. Please do not ask another question without giving us the detail. And it would be highly preferable if you would give us the results of pulling the codes in your very next post. |
Also, regarding the power - if the engine is still very newly rebuilt it will be tight, giving a 'resistant' feel driving.
All the engines I have rebuild & run-in have felt this way, then after a period you realize that resistance has (quite suddenly sometimes) gone, & the engine feels a lot freer. You can then also get a better tune up on the engine. |
(Post 11771726)
Originally Posted by Ken Blythen
(Post 11772241)
Also, if the engine is still very newly rebuilt it will be tight, giving a 'resistant ' feel driving.
On the EFI 302 w/AOD, there is a transmission TV (throttle valve) cable at the throttle body. It is adjustable, but be very careful, this is a 26 year old plastic housing! The cable core is pulled by the throttle linkage, if you are getting late, hard shifts, you need to unlatch the clip that hold the casing and move the casing toward the lever by one notch and relatch it. DO NOT GO A LARGE AMOUNT!! To far will make it slip and ultimately burn up your transmission.
Timing, if you haven't checked it since installing the engine, yes, it should have been set as soon as you warmed it up the first time. For all who need it, TFI distributors, if you set it so that the leading edge of the shutter is just at the center of the Hall effect pickup you will be almost dead on when you check it with a light. |
(Post 11772757)
Makes sense, what would be a better tune up? Would it be adjusting the timing?
Edit: I forgot you can turn the distributor. Duh! |
Timing has been set to the factory spec, but I thought maybe there was something like advancing it to maybe make it perform a little beter.
(Post 11772901)
(Post 11772757)
So as Gary says, the computer & EFI will be looking after tuning. |
