Do my heater hoses look different?
I don't recall seeing this configuration in any of the recent hose pics. Is the T in the hose running from the firewall to the passenger bloack normal? The T runs down to the radiator and clamps on near the drain valve.
http://i928.photobucket.com/albums/a...-30-37_963.jpg http://i928.photobucket.com/albums/a...-31-09_731.jpg |
Looks just like mine. I'm having a heck of time finding a 5/8" x 1/2" x 5/8" tee to replace the OEM one if need be. Could make up something if push comes to shove I guess. Not sure if anyone makes that hose anymore. Ford said no.
looks just like mine.
except my coolant tank isnt all brownish :-X03 what kind of coolant you runnin? well water? :-X04
Cool. I don't know what I though was different. I guess I've just missed that T in all the other pics.
Originally Posted by Ken_C
(Post 11756670)
1 Attachment(s)
Originally Posted by pjwoolw
(Post 11756615)
You can barely see the "T" behind the IC pipe in this pic :-drink |
fleetcharge isnt green? didnt know that. thats what I would use should the need arise.
(Post 11756710)
Just before I took off my tank started leaking. I've used a few used ones but this time I ordered a new one from partsguyed. My My, its so pretty with the pink Fleet Charge in a new whitest clear tank.
C'mon Glenn, you have to post a pic now.
Originally Posted by oldbird1965
(Post 11756866)
(Post 11756866)
dieselsite.com. You probably just want to DIY so I'm not much help. Good Luck
T is normal.
If I remember correctly I got a new lower hose to replace that one and although it had the proper bends to go under the radiator, it was just the lower hose from teh T down. I had to cut the T out of the old hoses and use it to make a new hose. |
I am thinking that there was something different in those hoses between the '96 I drive and the '95 I parted out. Maybe it was just the location of the T? I can't remember now, but I know that there was something different about either the heater hoses or the radiator hoses and their routing. I would have to pull them out of the loft and look at them again to see what the difference was.
