Ford Truck Enthusiasts Forums
-   Excursion - King of SUVs (https://www.ford-trucks.com/forums/forum29/)
-   -   programming the key fob (https://www.ford-trucks.com/forums/1155776-programming-the-key-fob.html)
lace 04-16-2012 11:14 PM
Just bought a 2005 excursion diesel and they handed me a key fob and said that all I have to do is program it. can anyone help me please.
lace 04-16-2012 11:21 PM
keyless entry
I forgot to add that this truck also has a keypad entry system. Does anyone know how to program that as well. Thanks in advance for any help.
Stewart_H 04-16-2012 11:50 PM
How to reprogram your keyless entry remote controls (97-up)
To program the transmitters yourself:
1. Insert a key in the ignition and without starting your car, turn the key from OFF to ON eight times in rapid succession (within 10 seconds) with the eighth turn ending in the ON position.
2. The doors will lock/unlock to confirm that programming mode has been entered.
3. Within 20 seconds, program a remote transmitter by pressing any button on the transmitter. The doors will lock/unlock to confirm that the remote transmitter has been programmed. If more than 20 seconds pass before pressing a remote transmitter button, the programming mode will exit and the procedure must be repeated.
4. Repeat the previous step to program additional remote transmitters. The doors will lock/unlock to confirm that each remote transmitter has been programmed.
5. When you have completed programming the remote transmitters, turn the ignition to OFF, or just wait 20 seconds. Again the doors will lock/unlock to confirm programming has been completed.
That's it!
Stewart
Stewart_H 04-16-2012 11:59 PM
Just FYI for anyone ever doing a search, the procedure for programming FOB's and PAT's keys has been added to the Tech Folder
https://www.ford-trucks.com/forums/1...l#post11719645
Stewart
Stewart_H 04-17-2012 12:02 AM
For your keyless entry pad, you need the master code in order to program a secondary code of your choice into it.
Stewart
lace 04-17-2012 12:21 AM
Thanks Stewart. Figured out the fob, but can't find the factory code for the keypad. any suggestions?
Stewart_H 04-17-2012 12:27 AM
https://www.ford-trucks.com/forums/1...l#post10496445
Stewart
jh818 04-17-2012 12:28 AM
Look behind the radio and down. You should see a box with a sticker on it with a 5 digit code. That code is your factory code.
Or, look behind the dash above the hump in the center for the box. There should be the sticker with the code on it.
lace 04-17-2012 12:53 AM
still can't find the factory code, but thanks for your help. I will tackle this again tomorrow.
