1989 ford f superduty 7.3 diesel
have a slight proablum. have 89 f superduty truck withe 7.3 diesel it was starting and running fine but today when i went to start and move it when you turn the key nothing happens the starter douse not engage or make any noise acts like ther is now power to any thing both battery fully charged and connected what should i look for any help appreatchiated thanks brian
When you turn the key to on do you have dash lights and gauges? May need to check that battery connections are clean and tight.
Also if you look on the pass side inner fender you should see the starter relay. You could jump the two big terminals on it with a wrench or similar and see if the starter then runs. If it does then you may have a bad neutral safety switch (if auto) or bad clutch interlock switch (if manual). If auto try moving the shifter to Neutral and trying it. |
1989 ford f super duty 7.3 diesel
got truck to startand run as it should but will need to replace the battery cables any body know of a good place to get the battery cables let me know thanks brian
Originally Posted by Xpebrian1
(Post 11708723)
have a slight proablum. have 89 f superduty truck withe 7.3 diesel it was starting and running fine but today when i went to start and move it when you turn the key nothing happens the starter douse not engage or make any noise acts like ther is now power to any thing both batterys charged and connected what should i look for any help appreatchiated thanks brian
Not good on electrics but maybe take the lower steering column shroud off and check that the rod that connects the key switch to the ignition switch is moving properly when you turn the key.
Also there is a big bunch of wires all connected to one big terminal on the fender mounted starter relay, some are fusible links, check that they are good. |
