6.7 Wind Noise and Door Rattle remedy
Hey everyone.
I know we have been talking about this some on the forum and after alot of research I wanted to post my results and findings. I hope this helps everyone. My superduty had rattles on the doors. It sounded like it was coming from the plastic inside part. I have battled thses for months and have finally found what it was. Come to find out is was the glue adhesive that Ford uses to put the moisture barrier in. The simple way to fix it was to duct tape all of the edges up behind the door skin. Tape up the moisture barrier at the edges and put the skin back on. I added some foam behind mine to firm up the plastic skin as well. It was tough getting the skin back on but sure did help it alot. I did this to both front doors. Was not necessary to the rear ones. With the wind noise beside the head on the drivers side.......At first I thought it was the window seal but that was not it come to find out. I looked a tthe passenger side and looked at the drivers wondering what it could be. I noticed that the drivers door at the top was not in line and laying flat with the rear door. From the plant......Ford had the door at the latch side too high. It was only off maybe 3 16th's......very small but I lowered the door with the striker. Got the door in line with the back door from top to bottom. I also did Epics door mod with the surgical tubing. I lined up the door and tested it a few times. Made minor adjustments and wah lah!!!! Solved. Im pretty sure I got 90% out of it. I can still hear A LITTLE but it may be my imagination. Its probably in my head at this point since I have been ticked at the truck since I bought it. My dealer wont help so it has been very frustrating. These are the tips to solve those problems. If you need any help or questions them pm me and I will be more than happy to help. I hope mine stays quiet. That wind noise thing has come and gone before so I will post in a few months on how shes doing. As for now I tightened everything down and am gonna let my 6.7 haul!!! :-jammin |
Good news then !
Looking at the continuous weatherstripping they have on my 12 cc lariat, I am stunned the wind noise is so bad ! Now I do run around without radio a lot cuz I like the quiet and hearing the engine, but man, I got's to do something about it myself.... Soon as I get the 5'er ready for our trip on the 25th, will redirect my attention to the wind noise ! |
My truck is also a little noisy. I am going to start with Epics door seal mod. I really appreciate all of his videos!
Tollie - Can you post pictures of the parts you adjusted to get the door in line? My imagination needs more coffee right now and I can't visualize this one. :)
:-huh What is an Epics Door Seal Mod ??
Thanks Savage :-wink
Thank EpicCowLick...
(but thank you) |
Originally Posted by Brandon Bloomquist
(Post 11699442)
I had a rattle in my door that drove me nuts (2012 F-150). I localized it to the window switch panel. The switch mechanism is in a frame , which is in a frame and they're all loose. I just pryed out the panel and stuffed some small pieces of foam in the loose frames. Connected it back up, popped it back in and rattle was gone. As always....YMMV. Cheers.
