Found a source for the IVS switch
Maybe a dupe ? I couldn't swallow $400 for a new pedal assembly. Did some searching using the part number of the IVS and found,
Onlinecomponents.com Manufacturer: Cutler Hammer Part # SS22BW32-330Y Hope this saves someone some cash. |
Did you order?
Originally Posted by cookie88
(Post 11692933)
Did you order?
Here is a link so no one has to search
SS22BW32-330Y CUTLER HAMMER/EATON is in stock | Buy SS22BW32 330Y | Onlinecomponents.com |
Good call. Sent this along to the keeper of the part number thread. Hopefully we can get this info added into that thread as well.
Reps sent! |
slightly bringing this thread up from the dead. but i just wanted to know, is this indeed the same momentary switch as in bolt in? thanks!
Yes, direct bolt in. Are you having problems with off idle ?
I just tuned my accel peddle and in the process i noticed my IVS is alittle sticky but i never noticed it before, maybe having my pedal tuned closer brings out the problem? but either way i could tell by ear that sometimes it doesnt release and sure enough the next day i went to drive it and i had to pump it a few times to un stick it ha.
oh btw would you be willing to sell that extra one you had to buy?
I just picked up a couple of these. I read on another site they were not gonna be made again after this stock is sold. There were like 80 I believe left. At 12 bucks a piece, its a lot cheaper than a new pedal assembly if needed.
Originally Posted by Stokes
(Post 12431031)
haha thats cool i understand, ill order two myself then.
I just bought a couple myself.
Good find!
It is the OEM part, even has "Ford" molded into the case and it has the metal bracket attached. ~DR |
Does anyone know if it is the same as the super duty's?
Red |
