Head Swappin' - '85 to '80? Breaker Dizzy?
Hiyas!
Anyone know if there's any differences at all between an '80 and an '85 300 head? I have a chance at a fresh head off the '85 with new springs, valves and rockers for a reasonable price. Just want to make sure all my old stuff will bolt up. Mine has no air pump, no nothing really - hand choke now, and what is apparently an earlier exhaust manifold. (no plugs from air pump) Best head gasket? (within reasonable price, anyhow...) And I'm still looking for a breaker-point distributor if anyone has one out there... :-huh |
Ford switched from rocker studs to bolt-down rockers sometime around '85, IIRC. My '86 has the bolt-down pedestal rockers. Other than that there should be no worries.
As Baron said, here's the difference between an '80 and an '85 head. It's all external:
My '81 head: https://www.supermotors.net/getfile/...e/img_3159.jpg https://www.supermotors.net/getfile/...e/img_3095.jpg The '84 head I swapped on: https://www.supermotors.net/getfile/...e/img_3297.jpg https://www.supermotors.net/getfile/...e/img_3302.jpg https://www.supermotors.net/getfile/...e/img_3303.jpg So, if the head you're looking at comes with all the Rocker Arms installed, you're pretty much covered. There are 3 different grades of FelPro head gaskets. The "economy" gasket, which is around $20. The "heavy duty" gasket, which is around $30. And the "high performance" gasket. Which is around $60. I'd go with the HD or HP gasket. Last thing you want for the head gasket is an economy version. |
Thanks for the photos, man! So no differences, my push rods should work as well as the lifters I really don't wanna have to pull out, and all bolt holes and such will line up for my manifolds. huzzah! $100 is pretty hard to pass up on for a re-done head with all new parts.
And as to the dizzy - I have the DSII - no worries. Just might like to have an old breaker-type around for - well.. "in case". I trust no electronics beyond regular wiring further than I can toss my truck when it comes to solar storms n' such. |
Originally Posted by DHCowdude
(Post 11677146)
