4x4 help on my 79
I used my 4x4 for the first time today
And after I free'd the hubs in the front, I shiffted it back into 2wd hi Though the front bar kept spinning though? I mean at idle, the bar dosent move but when I shift into first or second gear it starts to move is this normal? I've never really payed attention to my 4x4 until now |
I would climb under your truck and see if there is any free wheel capability of the front drive shaft. I bet it isn't disengaged at the transfer case or at the hubs.
Yeah, i tried again and moved the 4x4 shifter around a couple of times
and the hubs but the shaft spins very slowley when i go in first gear or reverse SO this is not normal right? iv heard on SOME trucks it is, is it on mine? |
To get it into 4wd....
1. lock in hubs 2. shift transfer lever into required range 4 H or 4 L 3. 4 wheel the hell out it..... Ok done pulling the chebby off the wet grass. 1. Put transfer case lever back to 2wd, I let my arm rest on the seat as a way to feel the slip from 4H to 2H since its gradual. 2. Get out and un lock both hubs 3. Drive truck backwards a few feet (some say 15) I always slowly drive left and right a bit and ck for that feeling that a hub/hubs are not locked in anymore. And yes the front axles and d/s can coast spin as I call it.... as long as it NOT be driven by the transfer case. Another way to make sure you are in 2wd is put xfer case in N the 1 notch back. |
(Post 11677665)
Ok done pulling the chebby off the wet grass. |
(Post 11677665)
I usually just put it in neutral, then pull it back until it drives (2wd) and leave it :-D -B |
What transfer case do you have? The detents should be fairly obvious. Any chance the clip popped off the t-case shifter and the lever isn't moving the selector arm on the T-case?
Originally Posted by earthquake68
(Post 11681980)
-Brad |
